0 Members and 76 Guests are viewing this topic.
MrSpates
@ Bruce
Wow Bruce that was really interesting! wonder what might happen if you put a few wraps on the Carbon tube and the galvanzed one and hooked them all in series? I'll be glued to this thread from now on.
Pirate88179
@ Bruce:
Great job!  We are finding out more and more about these things and it is great!
http://www.goldmine-elec-products.com/products.asp?dept=1174
Above is the link to the solar cells page on the site that Joe posted.
Yes, the cotton and the design of the NS cells will allow for series wiring.  This is why I feel that we can do the battery experiments we have been discussing earlier.  I think they have a great chance to work. (The single cell coil)  So, you added more mA's than would be had from adding the two separate cells together?  This is important.  This is telling us something.  Fantastic!  I will try the same this weekend and report.  I still believe we are into much more than we ever imagined here.
Pirate88179
@ MrSpates:
I have been thinking about the very same thing.  Why not wind my carbon electrode to see what happens?  If I get the chance, I will look into this as well.  Yes, please stay tuned here, some great things are about to be discovered.
Bruce_TPU
Quote from: Pirate88179 on February 14, 2008, 09:17:58 PM
@ MrSpates:
Hi Bill,
I honestly don't think that winding the carbon will suit a purpose.  The reason we need to wind over the iron (galvanized) is to enable it to be used as a pulsing transformer underground.  I think that the real experiments should be along both of the following lines, IMHO.
A.)  The continued work on our N.S. coils
B.) Verifying that putting power into our other North/ South Earth Battery electrodes, allows more power to be output.
This can be tested using batteries with a load, as those two posts made to your youtube video, or our coils, measuring the amperage of each and wiring our N.S. Coil in series with our E.B. Electrodes, as I did, and see if there is an "abnormal" increase in current.
Cheers,
Bruce
Pirate88179
