0 Members and 127 Guests are viewing this topic.
Bruce_TPU
Quote from: Pirate88179 on February 15, 2008, 12:46:12 AM
@ Bruce:
Gee, 81.8 mA?  Is that all?  That's only like FOUR times the amount my coil puts out!!!!!! Ha ha.  Nice work.  That is almost 1/10 of an amp.  We are playing in a much different ballpark now and that is the record.  Fantastic.  Interesting that the volts do not seem to increase with the additional windings and length though.  This is the same range Joe and I have.
Hypothesis:  If one built a coil 4 feet long with 20 layers, we might have several amps of power.  To me, power is everything here.  I still think we will see increases when buried, but, you might be right about the secondary too.  Time, and experiments, will tell.  Incredible Bruce, great job!
Hi Bill,
You are right in noticing no increase in voltage.  I ended up wiring mine completely in series.  And almost identical voltage as Freezer's coil, and his was wired in parallel.
This tells me that that it makes zero difference, wiring layers in series or parallel.  I urge series, simply for ease of winding.
Right now my coil is simply a galvanic battery (though pretty cool.)  What I need now, is to figure out what I want to wrap the secondary with, and work on connecting my relay and testing it.  I think the secondary will pump the telluric currents.
I am also ordering, in the morning an analog meter for volts and one for ma's.
@ Joe
Where do you reckon the "output" of our coils will be, once they are finished?  The output to load, that is?  Looked at the patent, and I have got it.
Night all,
Bruce
Freezer
Nice job Bruce!  It seems like vertical is the way to go.  They should get even more power in the ground, so I hope it goes well.  My water battery also acted like as you say, it wouldn't really matter whether in series or parallel.
Bruce_TPU
Morning all,
Well, I tried my large coil hooked in series with my N.S. Electrodes and all readings were normal.  In other words it behaved just as you would expect.
In series, 1.45 volts @ .12 ma's
In parallel .823 volts @ 60.8 ma's (coil had dried out some, over night, so lower ma's.)
Conclusion:
This evening, or tomorrow, I will repeat my experiment with baby coil.  If same results as yesterday afternoon, I will conclude that there needs to be a much higher ratio of volts to milliamps to see the effect.  If that is the case, I will hook some 9volts in series with my large coil, with the N.S. electrodes and see if there is a bump in amperage.
Also, tonight I will begin work on the secondary.  I have changed plans on that.  In the patent, I count seven layers of wire.  I will start with magnet wire and end with Litz wire.
Cheers all,
Bruce
Localjoe
Quote from: Bruce_TPU on February 14, 2008, 07:31:24 PM
@ Bill
Please repost that link for that cell, or PM it to me.  I would appreciate it very much.
@ Joe
Thanks!  It sounds like a great little relay.  I can't wait to see how it does hooked to your coil.
Ceers,
Bruce
@Bruce
Something you should think about, at frist i was with you on puttng a little extra juice in the primary but i really dont think its a good idea, when i did it i got weird bubbles ..... no bubbles when just the wires 5 and 6 to load so id be willing to say that by putting power into this with a relay would not be a good idea yet the graphic i drew a page or so back shows the earth battery with a built in relay powered off of its own wires so that may be worth a shot since it is passive and the rotary gap would be passive as well but the relay i was testing here for the step up circuit is acitve and probably should not be used.. Please dont mind me using audio terms active and passive  as  i didnt know how elese to describe what i was saying  ;D
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
MrSpates
Hi all,
Well I had an hour to spare this afternoon and my curiosity got the better of me, so I buried one of my microwave transformers about 4 inches in the ground and covered it up with all connecting wires sticking out of the soil, and hooked it to my copper pipe-zinc rod earth battery. I was a bit disappointed with the results:
.70 volts DC and .12 milliamps
I had quiet a start at first when my multimeter was set on microamps instead of milliamps (200u) as the meter jumped to 124 then continued to slowly fall over the next 20 min to 90.1 microamps. I had to quit as it was growing too dark to work with it. I left the transformer in the ground just to see if it might charge. I plan to work with it as time allows, plans include building a coil and hooking it up to that as well as to build an 8ga. antenna and setting it on top of my 7ft patio fence. I really have no idea what I'm doing, just trying to see what I can get from the different setups. Its an interesting hobby even if I never accomplish anything.
