0 Members and 78 Guests are viewing this topic.
Bruce_TPU
Quote from: MrSpates on February 15, 2008, 09:19:59 PM
Hi all,
Well I had an hour to spare this afternoon and my curiosity got the better of me, so I buried one of my microwave transformers about 4 inches in the ground and covered it up with all connecting wires sticking out of the soil, and hooked it to my copper pipe-zinc rod earth battery. I was a bit disappointed with the results:
.70 volts DC and .12 milliamps
I had quiet a start at first when my multimeter was set on microamps instead of milliamps (200u) as the meter jumped to 124 then continued to slowly fall over the next 20 min to 90.1 microamps. I had to quit as it was growing too dark to work with it. I left the transformer in the ground just to see if it might charge. I plan to work with it as time allows, plans include building a coil and hooking it up to that as well as to build an 8ga. antenna and setting it on top of my 7ft patio fence. I really have no idea what I'm doing, just trying to see what I can get from the different setups. Its an interesting hobby even if I never accomplish anything.
@ Mr.Spates
Try pulsing a transformer, while it is underground, and see if the output is more than the input.  That might prove to be an interesting experiment.
Just burying an un-energized transformer won't do much of anything.
Cheers,
Bruce
MrSpates
@ Bruce
What do you mean by pulsing it? using a wrapped coil? It was charged with .70 vdc little as that is.
Localjoe
@Bruce
Any tests today on your coil ? Need to find a good separator for the secondary from the primary that is removable. Should probably do like the patent says but hollow peice of wood that wide is a pain in the ass im going to have to bribe the stump guy..
        joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Bruce_TPU
Quote from: Localjoe on February 16, 2008, 12:18:34 AM
@Bruce
        joe
Hi Joe,
Just the test this morning that I posted.  I hope to run some Saturday.  It is raining, but that is good, eh?  LOL  As long as there is no lightning tomorrow, I will proceed.
I simply wrapped a couple more layers of cloth over my finished primary, (Bigger sponge to keep the whole thing wet.)  Then wrapped two secondary's.  One of magnet wire, 20 awg and one of Litz wire, 675 strands of individually insulated wire.
I used alligator clips as a hand relay make and break to pulse the coil.  I saw between 12 mv and .9 mv AC at each touch.  I don't know why, but numbers greatly varied at each touch.  The average seemed between 3 and 4 mv's.  Not a lot of juice to pulse the ground, but hey, maybe it grows and then you are pulsing with more and more.  Kind of like a "wind up effect", to get the ball rolling.  Was there ever any report of that, anyone??
Cheers,
Bruce
Localjoe
@Bruce
Cool
I think before going in the ground, you should try a high speed make and break im next to positive you ac readings will increase proportionally with speed ;) ;D
        Joe
