0 Members and 996 Guests are viewing this topic.
Localjoe
Jeanna
Its a cool effect but on the same token.  Take a inch by inch peice of copper sheet and hold a zinc skrew in the other hand while squeezing you'll find upwards of .7 volts or more.  ;D Ive wondered for a long time how this plays into ancient Egyptian jewelery. The pharos depicted with crystals and different rare metals ......  See what im getting at. Theres a whole separate leg of science with electricity and crystals that has yet to be endeavored .  Maybe fun for after this but cool exp.  I guess main thing with the ns battery here is to keep ourselves out of the loop.
Please dont take this as me not thinking your exp was cool because i imagine those elaborate coiled bracelets in the olden days of the dissimilar metals gold and another had another use than style .
If you take me up on the coil gun exp. Remember theres no primary or secondary involved here just a coil on a pen tube one peice of wire.  It just let me get equated to where the magnetic pulses were really going when i dumped the cap into the coil. ITs cool because you find out that even though the pulse 's peak is relative to the polarity of the juice your sending through the wires, thats what determines what end the projectile shoots out. Theres still a smaller pulse that comes out the opposite end at the exact same time.  As well i took some bismuth and layed slats of it under the end of the barrel just enough to prop it up and it gave me added range and velocity, as well i Plugged my opposite end the end i wasn't shooting out of with bismuth. IT will reflect a magnetic pulse from the weak end  And create a greater punch on the shooting end. Kinda like shooting a rock from a sling shot then having a second invisible projectile smack it from behind and accelerate it even faster than normal out of the barrel.
        Take care and enjoy
        Joe
PS if anyone ever wants to chat on a messenger thing i have skype and i use a windows messenger acct same as msn
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
jeanna
It's been hard getting on this site today. I hope all is well again.
I can't copy paste on firefox today! so I am just answering
@Mr Spates
I got around 450mvdc. but see below.
@Joe
So, do you think I am seeing a skin effect of the voltage going from one hand to the other? I would be a resistor in a circuit from left hand to right hand.
It is sort of like the earth battery itself isn't it. There is no contact with the metals but a big ocean of resistance that allows voltage (DC, AC, and some uA)  to occur between the probes.
If the metals touch each other I get zero voltage. I suppose that is what it is- the circuit is happening across my skin).
Oh well.
I was hoping we had an amplifier. I guess not.
jeanna
(my arrow keys don't work today either. Is it possible that they made changes that prevent these functions? arrgh!)
Pirate88179
@ Jeanna:
I too use firefox and am having no trouble.  My arrow keys work and I can copy and paste just fine.  Try exiting out of firefox and restarting your computer to reload everything.  If that does not work, download and use CCleaner (free) you can find free downloads on a google search.  This program cleans up a lot of left over stuff and frees up your system.  You may already know this but, in case you didn't I wanted to post it.  Good luck.
The OU site has been acting up a bit again today though.  I am almost getting used to it.
jeanna
Thanks Bill,
I think it is the site. Just now it took 5 -6 tries to make a reply. I switched to the browser I prefer to see, and it i.sn't any better. (but it behaves normally arrow keyswise.)
I just went outside with my meter and my 6 layer bimetal bifilar that I have been using for pure configuration checks. It is made with plastic coated tel. wire instead of cloth coated and moist.
There is no surprise, but if the site allows I will say that with the 10's attached to one magnesium block and copper pipe the terminals 5,6 read 1.14vdc. this is as it sould be. just checking.
I guess I was thinking if there is any real reason to want more than the .7vdc you could get from the galvanic reax of the coil wires themselves, this is a way to do it. This is an idea that came from the squeeze test.
Of course the terminals are not in their "preserved" state as they are being used to connect to other terminals, but they are terminals.
Another question:
I FINALLY got the mag wire I've been waiting for.
Bill,or anyone else,
Is there a consensus about how many turns I should use?
I was planning on using the whole thing (75 ft green RS mag wire, Or should I use the whole red spool-200 ft)
Any advice about this?
Any EXPERIENCE about this?
thank you,
jeanna
Pirate88179
@ Jeanna:
I have read, in several places, to use 3,000 turns for the secondary.  I think this would depend on a lot of variables but, it is probably safe to say that the more the merrier.  Joe can jump in here to see if this is correct or not, but, everything I have read about Tesla coils say, the more windings on the secondary, the higher the output.  I don't see why this should be any different.  The radio interview with that guy that wanted to charge $100/hour for phone call info on Stubblefield coils said 3,000 turns also.  I hope this helps.
