0 Members and 181 Guests are viewing this topic.
jeanna
Quote from: Localjoe on April 14, 2008, 01:54:20 PM
@Jeanna
He exlplaind that pretty well .. read it exactly how jim wrote it  ;) :-X
@jim
Cool ! how close is your local substation for power and what freq range was that repeating ringing wave spaned across
on your scope.  Just want to double check before i go asking ya more questions about it  :)
                                                              Joe
If you think so, tell me please,
does he JUST have 2 pipes in the ground? Al and Cu?
does he have a NS battery TOO? (I didn't think he made one yet) yet he refers to a "NS battery setup".
jeanna
Jestrue
@Localjoe
Did you even read the wiki entry... I never sad that you explode... do i have to spell everything out for you...
Ok, hold a nine volt battery to your Tongue... can you tell me what happens there?
The (salt) water on your tongue splits to hydrogen and oxygen witch isnt bad becaus its not in you blood stream just at the surface of your body. But the same reaction would happen in your blood streem and im sure you wuldend have gas in your blood streem. (else ask a doctor to give you a "air" Injection. (he wouldent, because he would kill you!) see my point with that??
The other thing. If you can produce electricity out of "nothing" your a magician... Im also not a physician or electrician but ther must be some kind of chemical reaction and in most of the chemical reactions there is waist...
(is there anyone out there who understands what I mean an is able to explain it in a proper English? for stuff like this my English isnt good enough!!!!
Magnethos
I haven?t read the 47 pages that this post has. Little by little, I will be reading all. I only can contribute to this, showing a device that I have thought and I have designed in the picture program.
I?m writing about this in Half-Baked Ideas.
Localjoe
Quote from: Jestrue on April 14, 2008, 02:40:50 PM
@Localjoe
Ive tested 9v 's that way my whole life to see if they were dead or not...... im still kickin
  Besides ... weve been through this electrolitic dicussion our cells produce less when salt is added to the water which concludes the water is acting as a dielectric not a electrolyte
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
Quote from: electricme on April 14, 2008, 09:59:02 AM
@ hello All
well I have just been doing a little experimenting with the cu & Al pipes in the ground
I have the scope connected to them, I decided to connect the ordinary old run of the mill garden LED light to it, similar to what Bill did on his UTube video.
There was NO 1.5 v battery, the solar cell is removed, the white LED lit quite brightly and was pulsating, haven't measures the current its drawing, but the voltage is .50 volt.
Now the exciting bit
I got a ordinary X mas tree light (1 bulb) and connected it along with the LED setup, while the LED was lit up, and the "bulb" began to glow, ever so weekly.
The bulb pulsates weekly alongside the LED and I can see the waveform on the cro pulsating at the same time.
current drawn 2.0ma
If I connect the Xmas light on its own, nothing, no light, it seems only to occur when the LED is connected in the circuit.
The LED circuit must be "pumping" or "exciting" the NS setup outside.
Jim
@jeanna
He was just describing a possible action of how the cell would work.. Let me simplify his exp for all it shows two good points
1)  The voltage present in the two rod setup must be ac , this is confirmed by the scope shot to start and the real conformation is this
2) The reason the christmas light will only light up with the diode in line with it is because the diode is rectifing the ac current to dc. Still we could take this further hes only rectifing a quarter or half wave with 1 diode full wave rectifiers have 4 to 6 diodes.   The light from the led is just a pleasent byproduct.
So waht we have learned here is that diodes will rectifiy more power here because its ac current and voltage were reading from the ground.  Where as unrectified the freq was not resonate of the christmas light so it did not light.
