electricme
@ joe
where did you get the fancy blue suit from ha ha (nice)
Yup, if you look closely at the MOV I made, you can see the AC moving quite fast, I think NS new this was in his inventions and to think he picked it up without the instruments we have today is quite amazing.
My theory is, if we can harness the ac to pulsing DC then feed it to a seperate coil it might just work.
After looking at the CRO at home aver a long period of time, I have come to the conclusion that the wave is composed of AC and DC, it is influenced by unknown interference, because it is never stable. It changes its shape, I mean it goes almost flatt, then later on, it goes into a sine wave, it can reach hi peaks and very low peaks, it has steps or high spikes and inverted spikes, it is crasy stuff.
Dosnt make any sence at all on some days.
When my LED is lit up, it changes brightness slowly or sharply, it might be very dimly lit, then goes extreamly bright.
Nothing is constant.
What I'm saying, the cycles of the energy are all over the place, if we use a accurate pulse rate to try and lock into its frequency, we wont be able to do it, we have to come up with a method to lock freq by using its own changing freq to do this.
But, did you notice that the top left of the wave form, there is something that appears and dissappears on and off, (like a lobe) don't know what it is.
Has anyone ever found an original NS circuit that has his coil connected to any device he made?
Jim
electricme
@ jeanna
Your Q on my setup at home,  here is how I have it setup.
I have the copper pipe (3f long) in the ground, about 10 meters away I have the 3f aluminium pipe in the ground, next I connected a extension lead to the pipes, ran it via the back yard, inside the house to the kitchen, (cause I'm lasy n donna wanna get cold or wet) :) then I connected the LED with its circuit to the end of the extension leads. Pos to Pos, Neg to Neg. I connected the CRO probes, Pos to Pos Neg to Neg (earth). I waited a while until it settled down, then  I bridged the Pos and Neg with the ends of the leads coming out of the bulb.
Thats the basics.
If you can, get a garden solar light, take it apart, look out for insects/bugs, (some twist off, others have phillips head screws).
The best place to get solar lights is to ask a neighbor who has had a few and ask them if they have one that dosent work.
(I found 18 in the dump last week)
Take a look inside the housing, it will have a small PCB (Printed Circuit Board).
Remove the Ni-Cad cell, then disconnect and remove the solar cell.
Next remove the red wire from the PCB going to the battery holder, "at the battery holder", do the same with the black negative wire.
Then put the POS lead that was going to the battery to the positive wire on your NS cell. Put the NEG wire that was going to the battery to the Neg side of the NS cell.
If there is enough energy in your NS cell, it just might turn on.
Hope this helps
Jim
electricme
@ jeanna
Thanks for the icon, TA muchly indeed  ;D
I only just found it.
Jim
electricme
@ all,
This is embarrassing, deeply embarrassing,  its 9.00pm, I got more energy coming out of these rods now tonight.
Yesterday I reported about the single LED being lit up and 1 filament bulb, but the bulb was extremely dim.
Tonight I hooked it back up, almost nothing, LED hardly glowed, then after a while I went back in the kitchen and I'll be blowed, it was really bright, so bright it hurt the eyes, I thought it would burn out, double checked and triple checked for anything unusual.
No, same as last night, so I added another LED unit (lighting 2 LEDs in parallel (yippee) and kept a eye on it, man, it too got even brighter than the 1s LED. (I'm getting dizzy)
I took a photo of it to prove it, in room light.
I then decided to add a 1.2 v DC Ni Cad battery to it, (Bat is dead flatt) joined a 12v Xmas tree globe in series and attached it across the line, it didn't collapse the feed coming in from out side, and the bulb was twice as bright as last night. After a half hr, the LEDs began to loose brightness very slowly, so I over did it, (too much load).
I removed all except for 1 LED and it started to come up to full brightness again. I couldn't look at it it was so bright.
My heads spinning. I think I'm on the right track.
Both CROs are hooked up to it, the B&W511 is keeping an eye in the power input, the new one is hooked up to the earth and to the + leg of the LED, as the energy gets more and more, the cro reflects that happenning also.
Turned off all the house lights, had no trouble looking around the kitchen, by the single LED lit the roof it was pointing at.
By the way,discovered something, that might have a bearing on the usage of globes, accidently by the way.
The setup gives out a half volt, it only seems to work with a 12v filament, but only dimly so far.
I tried connecting a 2.5v torch globe (.1 ohm) and it registered a instant short, it seems the circuit will only work if there is a higher resistance,(12 ohms or more) I will have to rig up a 9 pole switch I have somewhere, solder some bulbs in series and start experimenting with what will be the best setting.
hoo roo
Jim
Chad
@all
Ive been trying to think if we have missed something very simple in the operation of our earth cell, i remember Bill using salt in his water as an electrolyte with very bad results for his cell so i think we basicaly ruled out galvanic reaction as the main source of the cells power, this got me into thinking if there were something else that could be done that stubblefield may have done or unknowingly done to make his cells put out more power than ours?.
Well i was reading about NS and was given the impression he lived in or near woodlands/forests, this then got me thinking of something we may have all overlooked.. the actual soil makeup itself!, what if the acidity of the soil plays a role in the output of the cell?.
I thought id sacrifice a small cell that i first made when starting this project, so i placed it in a tall glass of cold water then took the following readings:-
.534 vdc
00.15 ma
Then i added ordinary malt vinegar at a ratio of 1% then left for 15 minuites to soak, then i came back and took the folowing readings:-
.723 vdc
22.00 ma
i couldnt believe how much power the cell was now producing and this cell is 3 layers.. wound on a 4" x 1/4" iron rod, so its very small.
so maybe as NS may have lived in the woods (can someone confirm this?) and as i understand it woodland has very acidic soils caused from rotting organic vegetation, ive also read that pine forests have very acidic soil so maybe NS buried the cells and had to wait for the soils acidity to soak through the entire cell for them to reach full power?.
just thought id throw this in here for more discussion as maybe a galvanic reaction could play a bigger role than we first thought?.
Chad.
