0 Members and 187 Guests are viewing this topic.
jeanna
Quote from: Chad on April 23, 2008, 12:47:04 PM
the small cell i used for testing a few days back has managed to produce a starting power reading of:-
.656vdc
162ma (yes realy that high!)
Hi Chad,
So, let me get this right,
You made a bifilar pancake with one copper wire covered in cloth, one iron wire bare. You soldered the B to the A (as the Tesla patent 512340 calls the wires) then you added malt vinegar, hold the chips  ;D, and measured the V n A. and what you got is posted above?
Now you are putting that pancake into or onto the ground? Any other insulation to or from the ground?
Jeanna
Pirate88179
@ Jeanna:
Maybe we don't need schematics for this stuff, maybe we just need menus.
Chad
@all
Sorry guys been busy winding again.
i was testing different electrolytes to see what effect they had on the cells, i tried malt vinegar and tap water (hold the chips ;) ) and i tried 5% sulphuric acid and tap water on both cells, the large cell aprox readings were as follows:-
.656 vdc
86mA
Then i tried the small cell in the same solution and the aprox readings were as follows:-
.656vdc
160+ mA
i know the electrolyte vastley improves the power output but it doesnt explain why the small cell has more power?.
I have looked closely at the first cell (smaller cell) and remebered i wound this one different to the large cell!, i remember that the copper wire was only 28g and the iron wire had a greater diameter of 2mm, i decided to loosley twist together 2 equal lengths of cu wire to increase the overall mass and diameter, i then wound these in bifilar fasion down the bolt along side the iron wire.
I dont know if this is the sole reason for the power gain over the large cell or not but i will wind yet another cell using this method to see if i can replecate the original small cell.
sorry if my methods go little ofcourse but once i have an idea i cannot let it go without testing it, i suppose this is how many big descoverys are made :-\  :D
Chad
Chad
Quote from: Pirate88179 on April 23, 2008, 04:57:59 PM
@ Jeanna:
@bill
lol this might not be to far from the truth :D
I was again thinking as i do and maybe we gain power from acidic soils like i first stated.. but also the hydrogen gas that is given off from the rotting vegetation, what if the hydrogen recombines with oxygen to form water wich creates a small electrical charge in our cell, if this process is happening all through the forrest floor then it would be like one giant cell with lotts of amperage....wouldnt it?.
maybe we could bury our own waste to create electricity?.
weres my spade :D
Chad.
jeanna
Quote from: Chad on April 23, 2008, 07:16:41 PM
Chad
Yaknow chad,
we are all experimenters and this is exactly how experimenters operate. schoolteachers don't like it much but it is just how we are. And, I agree this is how I, at least, invent things.
Also, it is why I am sooo insistent on getting good descriptions of what someone does right away. You might go off on a different tangent and forget this next week. I do that all the time.
So, Thanks for your good description of what you did to your NS coil.
Wow it is amazing
please keep us apprised!
Thank you,
jeanna
