0 Members and 46 Guests are viewing this topic.
Pirate88179
@ storre:
Crap!!  I did not notice that is says tinned and WAXED!  Hmm......I don't know how that might effect the coils.  Kinda expensive to take a chance.  Thanks for noticing that.  I was about ready to order some.
sid10
The only dumb question is the one that goes unasked.
petersone
Hi all,my first post,I think,but have been following this thead with great interest,a few comments on the simple test I have done.
My scope shows the voltage from my ground probs to be ac,about 8hz,but my meters will only read the amp and volts set at dc.
If I set at ac I get 0,Idon't understand that,I getting about 1 ma and 1/2 a volt.
Also, I found that a pipe,copper,steel etc.hammered into the ground fills up with soil and reduces the output,so I take out the pipe and empty it then replace it for a better reading.
I have tried a 2in dia steel pipe 3in long 2in in the ground scoop out the soil in the centre and put a copper pipe in the middle of the steel one,getting a decent reading.
just thought I would pass it on.
happy hunting.
peter
electricme
@peter
Welcome pete, any imput will be read and remarked on with humor (at times) ha ha.
Seriously, we are a great bunch here, we all do things a bit differently, and pull each others legs with gusto. ;D
I see you have a scope, great news, could you let us know how you got to see the 8hz on it? I have a 10mhz scope, but it seems because it is line powered, the earth is interferring with the results. Is your scope a battery powered one?. What is your scope set to?
Regarding your rods in the ground, the method you use to get more energy is probably what I need to use here, I will try and replicate your experiment and get back with the results shortly.
@ all
Has anyone tried using a brass tube as the + in a setup?
BTW I'm in the middle of making a doova to convert water to power my charriot, I'm using nickchroom wire I took off a small room air heater, I have a TENs, which has adjustable intensity and pulce with modulation, maby this will work with it.
I checked my rods in Dalby (my second site 50klms away) over the weekend, the voltage was 1.2v on my DMM, no load, in a week it has fallen to .9volt just sitting there doing nothing.
going outside now to try peters experiment.
jim
storre
Quote from: petersone on May 14, 2008, 06:11:25 PM
happy hunting.
peter
@ peter
I am feeling that putting it in the ground is more for just keeping it moist to help the electrolysis. It could be working with the natural south north flow of energy but it make not make a big difference if the ns battery is in the ground or above the ground. It just needs to be wet the same as wet cell needs to be wet to function.
