0 Members and 49 Guests are viewing this topic.
Anothertruthfinder
thanks for the welcome electricme  :)
i find it strange we all pretty much get the same efftects all around the world, shame we cant up the voltage somehow - some factor is missing in our experiments i believe
but point taken about the scope - cheers
ive done the water jar one as well, that got me about .89 volts dc using various electrodes, in the end i put a standard piece of copper wire and some aluminium foil hooked over the jar - which makes me think, is the ac on ground tests just current leak from pylons or our homes cause the earth must be saturated with leakage in this day and age, or something different - electric at a frequency of nature's notation and my digital meter interpreting it as ac......hmmm
sing the right note - smash the wineglass, get the right antenna - recieve the right wave, talk to nature in the right way - it talks back (goodness knows what language though! lol)
the earth's got unknown amounts of power to offer and it seems utter craziness we inefficiently tap its resources and inefficiently use them and the wrong resources we use
man has always been at the forefront of technology when it comes to killing himself - and we live in a supposed sane world?
ATF
Artic_Knight
i seen someone winding a bifilar coil with iron and copper, nice work :)
i havent been around much ive been sticking my nose in the bedini systems as i think i might have an edge there however i will say this after you try your bifilar coil out i recommend making 2 seperate coils and trying that as well. a known problem with bifilar or 2 wire coils is that if the current is allowed to flow in one wire it will create an opposite flow in the other. this will make for some interesting experiments  with trying the copper as its own filiment, IE one end of the copper wire is positive and the other negative with the iron doing the same (all be it opposite direction)  if hanz is around he could possibly elabrate on this as i think i saw him watching over the bedini sites too :) altho the opposite flow in the secondary wire is usually with copper and its induced from a magnetic field perspective. this may indeed have some interesting results with the iron wire :)
electricme
@Artic Knight
Welcome,
Thanks for your input, I must read your post again tomorrow when the old grey matter is fresh as a daisy, it seemed a bit confusing tonight to me.
@ all
Update on NS papers, I spoke to Hans today and by now he should have a complete copy of what I have, all 69 pages.
This weekend I hope to rescan in high resolutions and see what I can do about making them more easy to read.
@ Storrie
I apologise for not answering your question relating to Shorted Turns Testers, you might be able to pick up one on EBay or one of the electronic shops in your neck of the woods, other than that I dont know. Another instrument that could help us is a "megger" which is  a meter device that measures the breakdown of insulation around a conductor. There are two types, the ones one winds up with a handle, the other type one pushes a button.
Warning using meggers, dont drop the leads if a smartie winds the handle, one gets a fair size wallop if they do, a bit like the chicken handles that a electric shock game uses.
jim
Jim
uncleshorty
 Hello everyone, I'm a newbie too. I at first for thirty years tinkered with the hho concepts. After my last and final blast I swore it off till the tech. makes it safe. I saw Wild Bill,s You Tube video and saw something that I could try right away. I buried two copper plates hooked to a half inch twenty foot cable insulated. Oh yea I dug the hole for the copper plates till I hit the water table salt tidal. twenty feet soul th I put an aluminum three foot pipe two foot in the ground. I got about 3/4 volt dc.I could not get an LED to light. I took two strands of #10 insulated wire and ran it over a trellis. At one end I hooked up a green Led. The otherends went to the ends of the half inch copper between the plates and the pipe. I took a jumper from the aluminum  to one wire to one side of the led. the returning #10 wire was hooked to the neg. side of a stone cold dead 12 volt alarm battery. The 1/2 inch cable from the copper plates  went two the pos. side of the battery.The green LED lit and has been burning since. I also Bought a carbon rod and a magnesium rod only ten foot apart smaller wire same result except that has six red LED lights hooked up parallel also a circuit I found that says how to make a three volt LED work off of a 1.5 volt battery. These have been burning since April. Unlike other parts of the US we are in a drought But last week lightning storms are starting to show up. I look at the light in the morning And it got really bright it then returned to its  regular glow Then a large lightning strike happened. the LED blinked bright twice and then two lightning strikes. The LED seemed to pick up the energy moving toward the place where it happens. I just had to witness to you all that Good things are coming and it just around the bend. Cheers Bob!
Pirate88179
Bob:
I am WildBill on Youtube.  I am glad to see you here.  Interesting effects with the lighting.  I am still working back and forth between the electrodes and the coils.  I get more usable output from the electrodes at this point.  I like the carbon rod approach.  I am glad you got leds to light.  It is fun isn't it?  When my led was lit up I loved that it was running off the earth with no other power source, and would do so for as long as I wanted.  Welcome to our group here.  Please keep up your experiments and keep us posted.  There is a lot of knowledge here and if you read all of the back posts (good luck) you can see where we are at now.
We have another related topic in the Stubblefield coils and speculations topic.  These experiments are mostly dealing with the coil approach as well and there is a lot of information there too.
Anyway, I am glad to see you here.  Welcome.
Bill (Pirate 88179 and 0WildBill0)
