0 Members and 80 Guests are viewing this topic.
nightshade
electricme
The testing is going good back this way have just put a new setup in the ground.
went and brought five sheets of galvinised zinc roofing metal second hand picked it up at the local
demolition shop five sheets four four dollars they are 1 foot 3 high by 2 foot 9 long. I buryed them 1
foot in the ground and used copper pipes as well wacked these 3 feet in the ground
picked these up second hand as well  so the setup goes zinc steel
sheet then copper pipe only put in to sets so far getting 0.80 volts at 8.00ma . seem to be getting a
nice amperage but volts still low at the moment had a good amount of rain back here in new zealand
the day before christmas. I had tested each set and was getting 0.95 volts on each set but at the time
had not jumpered each plate so when the ground dries out some more ill post a update.
                                           merry christmas all
Pirate88179
smithandwes:
I just watched the video....it was a bit strange.  I guess he did not speak English?  I wish he would have outlined a little more about how his device is supposed to work.  I have never seen anything like this before.  Thanks.
timmy1729
Anyone that tries to keep a free energy device proprietary will have a lot of proving to do for people to believe it. I mean, if you're going to have something that violates known laws of physics, or at least appears to violate known laws of physics, keeping it to yourself will not work. Nobody will take it seriously because there is always the possibility of it being a trick. Being open about that kind of discovery is the only way to ever get it accepted as real. I think it's a fake, personally. Even Dr. Moray was open about his technology. The only thing he kept secret was his handmade tubes. I wish this guy the best of luck, but it is a wrong move to keep technology like this proprietary. Doing so sends off bells of it being a fake.
@Bill
I got a Craftsman multimeter for xmas! Now I can actually measure things! Ahhh, the simple things in life...
@everyone
I also got 3 magnesium fire starters. So, I have a good bit of magnesium(pure) to play with. Should I sandwich them together and bind them or should I set them side-by-side and make a plate from them? Also, if I were to wrap some cotton fabric around them and then some copper, would it still work since the Earth would only be touching a tiny part of the magnesium? I don't understand how those cells like Stubblefield's work in that manner. I can grasp the concept that it works if the copper is buried separately from the magnesium so there is ground contact on all sides of both, but I can't picture how it works making them into a cell. Anyone care to help me out here?
Pirate88179
@ Timmy:
Meters are fun, I'm glad you got one, you will need it.
As far as the mag blocks go, I am not sure.  I bound mine together to create more mass (I used plastic tie-wraps) but, it may be better to expose more area to the earth, I don't know.  It would be a good thing to try both ways and compare results.
As far as making a cell, I am not sure exactly what you mean.  Do you mean a cell where everything is in close proximity as in like a regular battery cell?  If this is what you mean, than all you will have is just a galvanic battery which will only give you 1.5 vdc max until the magnesium is used up. (Like any other battery)  Sticking the electrodes in the ground a good distance from each other, and aligned properly should allow you to see more volts than just galvanic and hopefully without the deterioration of your electrodes.  At one point, I was up in the 2.2 vdc range.  If you are talking about the Stubblefield coil, that is a different animal all together.  That is a bifilar wound coil with an iron core with cotton, or similar moisture "transparent" material separating the different metals.  That is a self-contained cell that works when buried in the ground.
As far as the laws of physics goes, everything I am doing on here for "free energy" or "overunity" complies with the known laws of physics and thermal dynamics. All I am hoping to do is to tap into either unknown energy sources or known but little used energy sources.  Kind of like if you had a solar cell 100 years ago.  They would think it was magic, or violating physics laws, etc. but all it is doing is converting the energy from the sun into electricity, a then unknown power source.  Some of my friends think I am nuts. (they may be right, who knows?)  I have tried to explain what I am doing, or trying to do and they laugh.  Oh well, I am having fun and learning a lot.  It keeps me out of trouble.
Good luck with your experiments.
