electricme
@all,
OK, I'm looking for ideas on what to use to assemble this thing.
How much spacing is the best between plates.
How deep should it be put in the ground.
I have 4 of  1/4" x 2 and 3/4" long, nylon bolts, but three might be better,adjustment wize.
Instead of using the center hole mount, I was thinking of using the above bolts.
I was thinking of either soldering a wire to each disk or driling a hole and fasten the lead by a small bolt and nut assembly.
jim
kukulcangod
It takes 3 or more days at my 2volts 1.23ma to charge to supercaps of 2.5volts 10 farads that is in parallel mode , series I just started volts go up much faster and I have now 4 supercaps of same capacity in series I will check in the morning 5 am so five hrs later that is to see how much the charged.....exciting! , the idea of the rotating supercaps sounds brilliant someone proposed the same for the bedini generator to constinuously do the same with its batteries don't know if someone ever done it, I do remember seen it years ago in bedinis old site , hopefully you electronic gurus will help us out on this one I m not an expert at adapting diagrams probably will take me weeks if Im lucky so in exchange I will post pictures from my wife's next trip to washingtong .......They are going to the smithsonian !! I will be working  :'( .....So I asked her to look for her descendant's(Alfred Vail) inventions /artifacts to try to find out if he left an example of an earth battery!! ......I can't believe the coincidence she was invited to the trip so Im trying to convince them to go there ........But is my goal as well for whenever I have the time .......So Bill and all thanks to your efforts and intelligence I get to put togheter in the future hundreds of tiny "fireflies" made out of small leds programed to behave as such ......That you can find in "instructables" website if interested , the program in the circuit lasts up to 5 months so her garden will be a very interesting place in the next days a lot of welding and researching about those circuits cause only one Jar is considered, thing is I want at least 400 like you Bill, distributed strategically in green her favorite color and in blue my favorite since it is the color of Bionergy as well........It will remaind me of the light that will guide me back home .....It will be my gift of love to and expecting mother of our first child....It remainds me of Manhattan in beautifull happy days of december full of lights.
Great Job guys Best Regards
jeanna
Quote from: electricme on June 08, 2009, 07:11:02 AM
@all,
jim
Hi jim,
this is not about how to assemble it, but instead a reminder that we found that a greater separation like 12 feet made a better eb.
Not a galvanic, but something that used the teluric currents.
This design seems pretty straight galvanic, which is fine, especially if the microbes of the earth provide the electrons to the Fe that are lost in the galvanic currents exchange.
Do you remember when I made the pots of cement? I was trying to make a separation because we could not get a series connection to work. If I remember it right, it only added about 0.1v to the 0.9 volts I was getting. So, yes it added, but not very much. I did not have much separation either... maybe 4 feet from neg to cement pot to copper pos.
I wish you good luck with this.
jeanna
electricme
@Jeanna,
Quote from: jeanna on June 09, 2009, 02:15:04 AM
Hi jim,
jeanna
Thank you, I think I am about 15 feet away from my other EB.
Tomorrow morning I will measure the distance to be sure.
jim
electricme
@all,
Here is the second and final jpgs of the making of my EB, to see the previous set, go back 1 page, TA
0889 = Drilling the Positive copper plate
0890 = Drilling the Negative steel plate
0891 = Making sure the nylon bolt will fit the hole drilled
0899 = Copper electrode needs a copper connector, steel needs a steel connector
0900 = Both disks completed, holes drilled, connectors attatched
0901 = EB cell is assembled, leads attatched
0903 = EB cell is seen side on view
0909 = Lead out wires go underground to fence.
In the summer the mower goes over the lot with ease
0912 = The EB cell is in the ground, a last view and checkup
0913 = All done
