jeanna
Hi everybody,
I was describing (and showing my pics of) my success to someone last night. (The success is with the joule thief and fluoro tube.)
He has a friend who has been experimenting with eb's and using vinegar.
As calmly as I could, I explained that as soon as you add the vinegar, you force the eb into galvanic mode and out of the magnetic mystery mode that it is in.
Then he said...
He understood that if you put a series of magnets between your probes you can enhance the eb.
We were interrupted at that point and there was no more said.
I think this is a good possibility and a great subject for investigation.
Anyone want to try it?
jeanna
Yortuk Festrunk
Is this tapping the earth's magnetic field?
From what I've been able to learn from this thread, you have one electrode in the ground, then a second electrode is placed in the ground at some distance from the first, with nothing else in between. And it is aligned north to south in line with the Earth's magnetic field.
If this is so, I have an idea that could potentially increase the output of your units many times over.
E.g., if you are presently reading 1 volt, this could boost it to 10 volts.
kukulcangod
Talking about series connections for this EB's I came across the fact that you must have a one shot one kill situation ,one big rod on north and south not separated ones if they are too close cause they don't work as Jeanna put it, so what I did after connecting in series and losing voltage was to add those 7 blocks of magnesium from waltmart to my round magnesium rod and from 1.5 volts  I now get 2.5 volts some days some other hot days only 1.5 and under a load of 2 3.5volt leds drops to .545 through my joule thief, a thing of beauty, so amperage increased up to 1.50 ma where before I had .500 ma or less, the blocks are attached to a plastic angle and interconnected on top of the magnesium rod  being attached with screws to the angle adding vertical length therefore getting a better output reading, homogeneus union sturdy connections are a must a small short or loose end and you get nothing,but of course mine is funky looking with radio shack alligator cables hooked up through the blocks screws, thing is other metals will take away from the output it has to be as much pure magnesium as possible , a copper wire through them for better contact works just  fine,but I have my doubts about that flint on the side,   my 4 ft. long 2''  carbon rod all the way into the ground , so I would suggest to just either join this metals to the top, south is out a foot or more, and of the same composition or just adding to the diameter underground same deal with the carbon rods a bunch of them as a unit will work better Im going to add one more rod or five of the same if finances permit to keep getting stuff powerfull enough for some practical use , can wait to find out and this is for the folks whom have a limited area like me I haven't even used pirate's suggested site for magnetic angle aligment another thing to test thank you for the link it saves an awfull lot of time, and I hope I can save you some as well, working in a team is better, at the same time Im working in a huge bedini wheel ,and somehow I pretend to hook it all up to my battery, one coil now with just a 4'' diameter pvc pipe and 7 single radio shack ceramic magnets gaining .5 volts at .100 amps at the secondary battery after 5 hrs with a 19 volt input not much but that's why adding more coils is critical on that 43'' diameter table top wheel and doubled magnet sets, still going on weak ceramics , 20 sets of them at least ...crazy for Im not near the output required to run such thing from the EB...But we shall find the way right folks?........so how did you say we boost the output Yortuk??
Keep up the good work
Pirate88179
Quote from: Yortuk Festrunk on June 12, 2009, 07:01:29 PM
It is aligned with the earth's Polar grid lines. (Meridians)  Not magnetic and depending on where you are located on the planet, this can be a huge difference.  That is why I posted the calculator link.  The bottom of the electrodes are aligned to match the magnetic dip angle for that particular area. Read up on Telluric currents (google) and the work done by the Russians.
the_big_m_in_ok
FreeEnergy said:
guys look at http://www.overunity.com/index.php/topic,948.msg46100.html#msg46100
@all,
Just an idea, possibly good for the Half Baked Ideas Forum:
Would it be feasible to combine the link above with this,
http://www.overunity.com/index.php?topic=5778.0  ?
Might make a spaceship if the cone coil has antigravity properties?  Just food for thought, as it were...
The Moderators may decide that's where this post belongs.  Or not.  Either way.
--Lee
the_big_m_in_ok
