0 Members and 76 Guests are viewing this topic.
protonmom
t3t4
As an example:  I tried to download the first file.  At Rapidshare it said "You are not a Premium User and will have to wait.  Please note that only Premium Users will get full download speed."  I don't have the $16.99 for 90 days of Rapid share Premium.  So I waited.  And waited.  Then when it was finally time to download...it says it will take 5 hours and 42 minutes.  Well, my computer would have been booted long before that.  I cannot get those files.  I do not have a fancy new computer.  I and 'puter are old.  Please post what you will, here at the forum... for us old ladies.
Thank you.
t3t4
Sorry about that, I wasn't at all thinking about those who still use dial up. It would be an almost impossible download at those connection speeds. I don't have a premium RS account either, I only use them because most others use them as well. If you have a preferred hosting site, just let me know and I'll upload the packet there also.
I had a long day yesterday, so I didn't bother resizing the pics to post. I was going to do that, but had already stared at my computer screen for way too long. Can someone tell me, does this site respond well to HTML in posts? I'm new to posting here, so I have to learn.
Thanks,
t3t4
jeanna
Quote from: t3t4 on August 26, 2009, 02:35:46 PM
... so I didn't bother resizing the pics to post. ...
How about resizing 3 or 4 pics of the current set up and see how it goes?
QuoteCan someone tell me, does this site respond well to HTML in posts? I'm new to posting here, so I have to learn.
If you mean in the reply box...
The reply box is php. You cannot even add an underline.
But you can change the predesigned color highlight to yellow by typing that in to replace the red, so I believe your leeway is very limited.
But if you were not so new, you would probably understand the reason for that.
For now, to help with your eyes... on the left edge is a choice to make for the "theme selector"
The pretty hot red and orange will pale to light blue and white. It might be easier on the eyes.
And finally, you are aware that you should be using firefox aren't you?
jeanna
xee2
@ jeanna
Quote from: jeanna on August 26, 2009, 03:06:57 PM
This must only work in Firefox. I have tried to change it in IE and it won't change. If anyone knows how please help. I do not like that orange and red.
dllabarre
Quote from: xee2 on August 26, 2009, 02:22:37 AM
@ dllabarre
Wow. This is very interesting. I have made a drawing to see if I understand what you are doing. Is this correct? How much voltage do you get?
I was comparing one sheet of aluminum covered with plexiglass to another sheet of aluminum NOT covered with plexiglass.  The aluminum sheets were 6"x24". Both sheets of aluminum were attached to the same piece of particle board 20"x32"x3/8" as you can see in the picture.  Only one sheet of aluminum had plexiglass on it.  Then I ran the 2 wires (1 from each sheet) down to the bottom of the pole to play with.
Today I replaced the aluminum sheets with aluminum foil cut into the same 6"x24" pieces with one covered with the same plexiglass I used before and the other with nothing covering it.
The mV's with the aluminum foil today were very low compared to what I got from the aluminum sheets yesterday.
Aluminum sheets 200-400mV.
Aluminum foil 20-34mV.
Everything else being equal.
DonL
