0 Members and 40 Guests are viewing this topic.
dllabarre
Can some one with an inductance meter and a bifilar toroid try this for me?
I was measuring some of the toroids I have taken out of devices like TVs and computer power supplies when I came across something strange.
First I measured the inductance when connected to the beginning and end of the first wire and got 36.8uH.  Then the beginning and end of the second wire and got 36.6uH.
I'm always for trying something really strange just to see what happens.
I then measured connected to the beginning of the first and to the end of the second wire and got 239.1H.... Yes Henries.  Not mH or uH but Henries.  I don't know if I could actually connect this toroid like this in a circuit and have it work this way but it would be really cool if it did.  This does not work with ferrite core rods.  I tried.
Here's the toroid I measured:
t3t4
What is the core on this toroid?
What you just described sound so much like my air coils.
t3t4
dllabarre
Quote from: t3t4 on September 01, 2009, 12:59:44 AM
t3t4
I'm not sure.  It's heavy like a ferrite core.  Not plastic or anything light like that.
DonL
t3t4
Well, chances are, that you just found the beginning to the end in either case. I too play with bi-filer coils, but I choose to use them where they can resonate most freely. Actually, I just wrap the coil around an empty beer bottle. Yeah, no kidding! But I do this in such a way as to make it adjustable. But that's just me...
Thanks,
t3t4
t3t4
@ Don,
QuoteMy results from the 2 aluminum plates got worse when I unattached the wires from the pole and insulated them from touching the pole and even  worse by separating the 2 wires from each other.
So my conclusion is that most of the mV I was getting came from the wires being attached to the pole and the wires being together even though insulataed from each other.  I was using a standard 12/2 with ground house wire.  The kind of wire that's in the walls of houses.
Now I'm moving on from using the pole and aluminum plates.
Sorry Don, I just got the email about this post. I do commend your efforts, but do please keep and utilize the pole! The aluminum plates work well under different circumstances, but the wire in the sky seems to work much better. I am having a hard time backing up what I have said. But rest assured, I will prove it!
What I would like to know is this: Why are you and jeanna having difficulty duplicating my results?
More pic's please, or video demonstration.
I know now from re-running my previous experiments, that it's not as easy as I once thought is was. But I still don't understand why none have matched me, let alone exceed my results. So in this case, please help me help you! I will do my best, as best I can do.
Thanks,
t3t4
