MW383
Quote from: jeanna on October 06, 2009, 04:12:12 PM
There very well might be a magnetic activity that goes along the iron wire because it is coupled magnetically with the copper wire.
I do hope you make another one with one strand being iron.
You are right! I will rewind this unit to have copper and iron. I like this breaking things down into pieces approach. I think once we have a good understanding of coil / magnetic field behavior, other aspects will more easily fall into place (hopefully)
I'm glad to be here. This is really fun. I just wish I was more electrically knowledgable. I'm more from the mechanical side of the fence with a dash of electrochemistry thrown in. I can wire a house or an appliance but these types of circuits are crude compared with the stuff you guys are used to. I will try to be as useful as I can here at any rate.
ok, i just built another unit; copper + iron. 3 individual layers. by this I mean that each layer has its own set of leads. all leads open ended right now, not attached to each other or anything else.
*iron 1 -------------------------coil----------------------- iron 1
copper 1 ----------------------coil----------------------- copper 1
-iron 2 -------------------------coil----------------------- iron 2*
copper 2 ----------------------coil-----------------------copper 2
+iron 3 -------------------------coil----------------------- iron 3
copper 3 ----------------------coil-----------------------copper 3
if I attach a 1.5v AA battery (positive to iron 3 left side, negative to iron 2 left side, see above +/- markings for battery attach points) I can measure 164mA current between iron 1 left side and iron 2 right side (see * marks above for multimeter attach points). On another note, AA battery doing fine, not dead shorted or overheating. AA battery by itself measures 207mA.
I have no shorts in the system. what am I seeing here?
Mezalon
Looking for any designs and shematic on earth batteries, especialy those usind a layed sheet design.
Mezalon
MW383
I am still playing with the dry coil consisting of iron and copper coils. Again, there are three layers of coils here, one on top of another. Coils each have iron and copper wound side by side. Each coil layer has open ended wires at each end, not connected to anything - just hanging out in the breeze.
So I am basically supply power to various coil ends on its left side wires only. All coil ends on right side open ended and hanging in the breeze.
Various combinations of power input points produce interesting interesting mA readings at same or different location in regards to power input points. All from powering only one side of coil. I would love to have an expert explain this to me. Build a three layer coil like this one and try it out! Meanwhile I will collect data and attempt to summarize.
MW383
MW383
introducing external magnetism to this coil when powered also creates interesting results.
well in applying voltage to the copper leads and measuring things, nothing is out of the ordinary. I didn't think anything would be.
My problems lie in inconsistent iron results. I am going to build yet another dry coil. iron only. like this current coil, 3 layers w/ all open leads.
Either I have a problem with my current coil in its construction, or something new is happening here. I can't say which without further confirmation. Hence rebuild iron only coil and try to duplicate anomoly.
I'll post later.....
