0 Members and 49 Guests are viewing this topic.
jeanna
Hey everybody check this out.
Here is a good start. I will check back for more in the morning!
http://www.youtube.com/watch?v=5j4piAI_igE
an electroscope (a fancy one, not like the one I made!) and a culomb meter!
Charging something by induction!!
wow cool!
(and I am thinking about those balls atop the NS generators again- ha!)
jeanna
lasersaber
QuoteEarth Batteries use very high impedance, that means that the coils have many turns in the thousands, hard to wind.
This seems to be right in line with my observations.  I have run well over a thousand feet of wire and the current just kept getting stronger.
I have decided to start my own Stubblefield replication.  I have read over his patent for the last few months and I think I know exactly how his design works.  I will build one exactly as I understand his design and see what happens.
protonmom
@John Bedini:
Hello and welcome.  I hope you will stay here with us and direct us in the making of these Stubblefield coils.  Is there any way we can get copies of the Borderlands articles?  Or, could you make a pdf and post it in the downloads section for us?  On the Stubblefield photos there are posts in the ground with globes on top of them.  What were they used for and how do we make them?  Any help would be much appreciated by all of us.
john_bedini
To all,
Just remember that earth currents run one against each other in streams so choose your area correctly. Semiconductor devices are based on current flow, low impedance. Earth batteries work the other way around with very high impedance, high resistance. The galvanometer must be wound with very fine wire to react to this feeble current. where does the radiant electricity show up? It shows up in  a high impedance without the use of current.
People like to call this back emf. The back emf of the system is always much lower then the input voltage. The spike is the true Radiant energy and it can do things current can not do. It can charge batteries, run motors, light lights and so on. Converting the Radiant energy must be converted in the collector circuit with a semiconductor and not the emitter. You must drain that off to charge something like a capacitor, and then only is it real measurable electricity. So you must understand the system you are trying to build first.
Earth batteries must be converted through capacitors then be switch in the arrangement of capacitors for the proper voltage to power things. The SG is an example of collecting Radiant energy and converting it by chemical reaction into a second battery. "Get an Earth Oscillator running and collect the Radiant energy into a capacitor". Stubblefield is just a starting point for this energy. You have posted about collecting energy from trees, you just do not have the switching circuits. Remember it takes some power to run that switching, but they did not talk about that.
John B
Quote from: lasersaber on January 29, 2010, 06:43:48 AM
john_bedini
Protonmom,
I will ask for the information from the guy that had all this. I do not know if he will let me scan it. But I will be posting some links to some circuits that will help. The most important thing is building an "Earth Oscillating Circuit" as I just said in one post. Do not look for much in the beginning as this takes allot of work to do. Stubbelfield had the first Earth Pulse Motor, I did point that out on my pages, I could not say everything as Time did not permit me to do that as I was more worried about my wife with her kidney transplant. Thank God everything worked out. You here have made great progress in learning about Earth currents, you have most of it. I was lucky that I live very close to the dense forests here and had friends who showed me old telegraph stations, the Earth batteries are still working here. They measure about 1 volt and no current but yet things still work for no reason receivers still click away, no one at the other end. They used the old Daniel cells, dead but still working. http://en.wikipedia.org/wiki/Daniell_cell
The plates in the ground are 8 feet by 16 feet by 2 inches thick and were miles apart, so this should give some indication of the impedance involved. These stations are no longer used and the plates have not corroded away at all. These are all old mining towns up here. The old timers here say that at certain time of the night they see sparks jumping across the ground. All this stuff is on forest service land all gated now and a fine if you get caught trespassing on the government land. And what Stubbelfield should have called it was self powering earth oscillator for generating usable power.
John B
Quote from: protonmom on January 29, 2010, 01:20:30 PM
@John Bedini:
