jeanna
 ;D
Not at 10 degrees, anyway!
Winter is a good time for theories.
It is a very interesting point about the 2 metals BEING a different phase. I always thought of it as different resistances, and never noticed what you said.
Thanks,
jeanna
Pirate88179
Jeanna:
10 degrees? (F)  Heck it was 2 degrees here last night and we got a foot of snow yesterday!!!
I was outside and I can't even see any of my electrodes or wires on the old EER.
Spring is coming!
guruji
Hi John thanks for your circuits I've build two single coil  motors and one double coil of yours and a bedini/imhotep fan too.
I've build a JT/bedini that worked well without a rotor.
Yes your idea is right one can do a joule thief to the Earth battery to power it more than drain to a cap then continue to another pulse circuit again to amplify more.
How can we find a right site for the earth battery is there a meter to know?
Thanks
john_bedini
Guruji,
Yes this is the way to go, just like a bucket brigade charging system. But the stages must keep going forward. Start with a small oscillator and move to the next oscillator.
This would keep building up power. Some of the solar light circuits would just work fine. I think the pages are called Talkingelectronics. look under Solar charger. Some very good circuits for this.http://www.talkingelectronics.com/te_interactive_index.html
John B
Quote from: guruji on February 01, 2010, 02:38:27 PM
Thanks
tishatang
Hi All
I've been thinking about what John B said about high impedance and using caps.  There is a way to capacitor couple two circuits together using the concept of the C-stack here:
http://jnaudin.free.fr/cstack/index.htm
Just brain storming here--Supposed I took four large sheets of aluminum roofing, separated by thin film plastic sheets.  Put them together as a C-stack.  then hooked the top piece to an antenna, the bottom piece to earth ground,  maybe also include a multi=turn fine wire inductor (car ignition coil) buried in the ground wired as a parallel resonant circuit (tank circuit) to collect earth energies.  Then use the two inner plates of the C-stack as input for the nest stage?
If you drew energy off the second stage, would it upset the natural resonant freq of the first stage?  this would for sure happen with inductive transformer coupling.  Maybe Capacitor coupling will isolate the load of the second stage transferring back to the first stage.  Maybe there are other ways to isolate load transference  since John talks about it and Moray did it?
I am limited in my knowledge about circuits.  Just tossing the idea out because I always like this idea of the C-stack.
