resonanceman
Quote from: Freezer on February 03, 2010, 09:32:00 PM
Question is, how do you know you have it, when we have nothing to detect it, or do we?
Freezer
John suggested an electroscope on a previous post.
Just  a piece  of foil hanging  over a wire ......in a jar.
If  the foil hangs straight down there is no charge
If  it pushes away from itself  ....you have a charge
gary
Freezer
Quote from: resonanceman on February 03, 2010, 09:49:26 PM
Freezer
gary
Yes, thanks, I'm going to try that out, seems simple enough to build.
ramset
Thanks Grandma
electricme
Resonanceman,
Gary, you have been involved in the stubblefield arena for some years, you have achieved a fair bit during this time, you have posted really helpful suggestions also have replicated successfully and we respect this, but, your last posts on your reflections about receiving and complaining about the type of "advice" is way off beam chum, and bordering on extreme rudeness.
Mabe you had a rough day at the office, so do we all at times, BUT, we need to reign in our "blunt" thoughts sometimes.
OK, it's a free world, and we all have an "opinion" and like to share it with others, but there are ways to express one self without belting the ears publically of the "teacher".
As John has said, he is not going to "spoon feed" us, and frankly, he is correct, John wants you to begin to think outside the "square" begin to stretch your grey matter a bit as this is how we learn.
I would love every question I ever asked to be answered stright away, but it simply isn't possible, and I would NOT learn properly.
In a PM, I asked someone the other day about a certain matter about Ultra Violet and Rife, it was several days before I got a reply, it wasn't ,,,this will do this or this will do that,, rather it was "indicated" to me on a single line, I was on the right track and I thank that person.
How did I react? when I read it, I said WOWWwwwwww,  I said, here was an astounding answer I could understand, and the answer was HUGE in it's implications, and I sent off a short thank you.
In regards to the "ford ignition coil" you indicate you are not interrested, but John was giving you and US all, a precious "KEY" to one of the most essential "components" to make the Stubblefield coil work without actually telling you word by word, blow by blow.
I have posted just this "key" several times, but no one "bothered" to understand me, and actually build it, because they might have thought "how does it fit into the layout of things" and ignored it, so we are our worst enemy.
If you had "bothered" to go and google Henry Fords Coil, you would have found a photo of this item, (my own dad spoke about these things when I was a nipper) and said they are capable of knocking you on your BUM hard. You would have also have "seen" the inturnel circuitry, its "trembler" switch.
Ask at a car measum to take a look at one, its all "keys" into getting the stubblefield coil working.
My dad said, that when a ford ign coil (key (in it's wooden box)) was fittered to the "outside" of a vehicle, it was a good crowd knocker downer.
Then you are lamenting further on in your post, you don't know the answers, do yourself a favor, GET OFF YOUR BACKSIDE AND LOOK man and stop attacking the single most amazing man alive today who I rate with the greats in the field of inventions and knowledge.
If you are not prepared to "research" the topic, then find something else thats easier to do.
So pull your horns in mate.
TO ALL, (and me too)
The trembler switch as John has posted is just that, I can see "why" he has posted this information, and to explain this you need to know that the magetic energy does not flow in a rythemic pattern, as we seem to think it does. (research research research) I posted in the past, I read where a woman could actually "see" this energy as a green wave of troufts and wave tops like the sea. IT EXISTS.
This "energy" is by it's very nature "twists and turns" and follows it's own parth, (sometimes several streams as John has indicated)  hence John has said, look for a favorable location and pick the best area to place the instrument.
Stubblefield gave a good hint, look for evergreen trees.
What instrument? a moving coil meter, galvometer type of instrument, also the Hivolt tin foil meter (Iindicator), sorry all, the humble DMM will have to be put away until later on. Use a neon "tube"
Like a stream of water, sometimes it flows at a trickle, later on as a rushing torrent, sometimes it can even move away from it's normal water coarse or channel.
And THAT IS WHY you need to make a switch that can keep in sync with the fluxuating nature of this energy. As each wave passes by the stubblefield coil, it ill impart energy into the coil, then at the peek of this passing energy, the "switch" opens, the magnetic energy is dumped, the lines of magnetic flux collapses and the INDUCED voltage appears in the secondary coil.
The mechanical reed switch automatically reacts to the fluxations in the frequency of the magnetic field exactly, Thats why we need to use it.
Without a magnetic sencing switch, the coil gets saturated and it just cannot work.
How to make a mechanical reed switch? Its similer to an ordinary soloinoid or relay that many cars have.
It will have 2 contacts, one contact will need to be fixed solid so it cannot move, make it out of wood with a brass screw contact.
Make the next contact out of a stiff but slightly flexable bar of something.
Glue a iron bit under the 2nd flexing bar. Place this close as possible to the strongest magnetic field.
Line the lot up and mount it so it can "sence" the magnetic field in the iron bar and the iron bifilar turns.
I may be wrong about this, but I cannot see a set of wires coming out of the bottom of the NS coil NS patent and this reflects what John mentioned of placing the switcher inside the NS coil assembly. How I simply don't know right now, but like the old 2 or 3 coil mechanical generator regulators, (Lucas, Bosch) they had adjustable screws and leavers to adjust the point "gaps" and coil tensions, so this is something else we will need to look at.
Gary, as far as I am concerned, you are still a team player, if I get out of line, I'm sure you will be the frst one to let me know.
Jeanna, I see someone else answered your Q for me, no worries.
John, I value your input immensly and hope you will remain with us.
hooroo
jim
electricme
@All,
The Nathan Stubblefield Papers.
The following bears repeating, a couple of orig NS members here will already be aware of this, but others may not know of this information so I will repeat it.
A couple of years ago, on the forum, (LocalJoe's) we were passing back and forth the cotton and silk arguments on copper wires etc etc.
During this I became aware of an old trunk which contained some of Nathan Stubblefield PAPERS, it was "discovered" just reciently (back then) and I made a special effort to find out the contents of it.
This trunk was given many many years ago to the University of Kentucky, I contacted the people looking after this "trunk" and requested they photo copy any papers that might be inside it.
A couple of people went and visited the Nathan Stubblefield Display there and posted photos of what they had seen.
There were 69 pages involved, most were very tatty looking, and had been affected by the ingress of the elements, but they are still readable.
Some images in these papers do exist in better shape on other web sites, so there is a different supply source of original NS work.
It may be that these have all been publically released, I don't know, but if you want a copy, let me know your preferred email address, to get them to you.
I will send them in batches and hope my ISP is alowing attatchments, if not, then I will try later at night.
jim
