0 Members and 144 Guests are viewing this topic.
akashh
akashh
@nightlife:  I guess that a new thread would be good, since we're really focussed on trying to find a way of harvesting the earth's energy here - although it does diverge into other topics in the meantime, but we somehow manage to bring it back to topic.
@all:  the copper pipe video is good, but according to me that's purely galvanic - notice the way the plastic is insulating the copper from the ground.  Also the fact that he can get double the voltage by putting 2 in series indicates that it is not connected to the earth.  The same voltage will be present if you were to remove the 2 rods and place them on a table (I tried it some time ago) but that's all it is - purely voltage.
I would try and set a first goal for us.  Let's say getting 10 or 20 mA at 1.2 or more volts.  This would allow us to use the circuit i posted earlier for a practical application:  garden lights running off earth energy.  We could then figure out how to scale up, but for those experimenting this would at least give us a target.
nightlife
akashh, I believe the earths energy is based on frenquencies.
Artic_Knight
just got back from the hardware store and here in cumming there is definately 8 ft grounding Rods of copper and a galvanized steel i believe. the rods are about a half inch thick and perfect for hammering into the ground. they look soo beautiful! HEHEHEHE   oh yea if you need some copper wire i found some bare copper nice roll of it in the welding section.  no graphite rods tho :(
jeanna
Quote from: akashh on December 16, 2007, 07:44:55 AM
Hi guys,
I asked 2toxic4u to post his video here because it is a replication of the paper referred to on this thread a while ago, I think this thread.
Take a look at all 10 pages.
http://www.theverylastpageoftheinternet.com/forsale/plans/earthbattery/ebpage1.htm
On the one hand it seems purely galvanic but as he says and I experienced, if two of these cells are put in the earth as a series set up the voltage drops to ZERO (!) And I only got .7 or .9 volts from each one before I put them in series. I is too odd.
So, please let me understand you. You made 2 cells each using a copper pipe, and filled with damp earth with a zinc plug which you connected in series on an inside table and you got 3 volts?
At this moment I am watching as 2 probes stuck directly into sand wetted (only damp) with 5% salt solution show an increase in volts from 0.001,  35 minutes ago to 0.086 volts now and still rising. This is a control for the pyramid thread and I think this thread too but it is inside the house not either under the pyramid or stuck deep in the ground.
It is funny I was just wondering if my presence was doing something. Thanks Hans for that terrific quote from Stubblefield.
OOPS, not Hans but tishatang
jeanna
