Pirate88179
Laser:
Excellent job on the make/break and your coil.  I'll bet your secondary will really put out some power.  We, as a group, have discussed several ways to utilize a make/break device but you are the first here to build one, and it works great.
Very well done.
conradelektro
Hello LaserJaber,
your Stubblefield Coil experiments are one of the best contributions I saw on overunity-com. Thank you very much for the photos, videos and hints where to get the wire.
It helps very much to have precise specifications when trying to replicate an idea. And it saves a lot of effort and money when one can start with the right materials.
Please excuse me for nagging you with questions. I would like to know as much as possible before starting my own coil. Here a summery of what I gathered from your postings and what I would like to know in addition.
I am talking about the coil you show in the video
http://www.youtube.com/watch?v=VGV-yiQ2WOE:
- copper wire: 125g 0.9mm Double Cotton Covered Copper Wire (http://wires.co.uk/acatalog/dcc_wire.html)?
- iron wire: 1kg 0.9mm Galvanised Iron Wire (http://wires.co.uk/acatalog/fe_galv.html)?
- which reed switch did you use?
- diameter of your wooden disks ?
- height of your coil ?
- You said to have used cotton between the layers of the winding? Was this some cotton cloth or a cotton string you wound on the coil?
- iron core material ? (I know you are looking for a Ferrite core; I am also looking for one and let you know once I found something; I am thinking about using stacked Ferrite beads http://en.wikipedia.org/wiki/Ferrite_bead)
Greetings, Conrad
guruji
Hi guys when reading Stubblefield patent again I am understanding that he is saying to do a bifilar winding with copper and iron wire with copper wire in the end as secondary.
Are there others that understood it like me?
Thanks
Rapadura
Wow...
This cotton covered coil is one of the great misteries of Universe!
Any scientific explanation for the source of energy of this coil? Telluric currents, like in Earth batteries??
Keep on keeping on, lasersaber!
wintermuteai1
Quote from: Rapadura on March 19, 2010, 08:50:53 AM
Wow...
Yes, the Stubblefield device can be primed ("prime the pump" as NBS often said)in more than one way. Notice that in using water the effects only truly started to be noticed after it dryed out quite a bit. The electrolytic action of either dunking in water and letting it air dry, or placing it in the earth and letting the natural moisture of the ground as well as the currents of the earth process the device. (you can also connect the #5 & #6 wires to make the device function as an electromagnet) Now, it is of my opinion that once this is done either way the device then starts doing it's job as a zpe(zero point energy)converter. If the coil is done properly it will naturally gather radiant/zpe energy from the vacuum and convert to useable current. One could further this device by tuning it so as to increase the frequency of natural zpe all around us. This device is another that is similar to function as a zpe collector just as Moray's valve did so in conjunction with an antenna to "zero in"/Tune in to the correct frequency/frequencies.
(Not to derail but to add to this:)
I also had wanted to say to those doing the crystal batteries in the other thread that After much research into these subjects I believe that the crystal batteries are also like the moray valve and the NBS device in that they are zpe collector/converters. If one were to add tuning coils and the correct antenna you could increase your volts/amps many many times over. (just my thoughts)
