protonmom
Quote from: conradelektro on March 20, 2010, 09:55:59 AM
It is the old "I want to become rich and therefore I keep the real secrets to myself" that leads people to do this little tricks, and specially laymen and lone inventors are prone to it.
Greetings, Conrad
Hello Conrad,
It might be true that SOME people do those tricks, so that they can preserve their secrets for themselves, but what is also true is that sometimes inventors didn't put certain things in their patents because the little stuff they left out was just "common knowledge".  Everyone KNEW those little things back then, so why repeat it?
It is too bad WE are not taught all the important things of how things operate anymore.  Every school should be teaching those things to the children from the beginning, but we have either gotten "lazy" or we have decided that basic information is no longer necessary since we now have such state of the art, high tech equipment.  I would like to know the basics, myself.
protonmom
@LaserSaber
On one of my coils, which has dried out for nearly a month now, and never been buried, I got a reading last night of V= .432  and A= 2.94
I have been hooking up the inner cu to the pos of meter and outer fe to neg of meter.
I also notice that there is a lot of activity around the outside of the coil.  I couldn't find my compass, so I used two neos hooked together on a string of thread and dangled it on the side of the coil.  It started spinning, faster and faster until it had wound the thread pretty tight.  I took it away from the coil and straightened out the thread to make sure it was straight, and then tried it again.  Same thing.  It spins all around the coil...some places stronger than others.  At the bottom end it seemed to want to reverse itself.
Then, after I was all done playing with the coils, and it was time for bed, I just set them aside and crawled into bed.  But I couldn't stand the smell of the ozone, or DOR or whatever it is that I can smell when the coils are operating.  So I had to remove them to the other room.  But I could still smell it for a while.  The same thing happens with large jts....only that smell is worse.  I consider the jt smell to probably be DOR and the coil to probably be ozone.  Anyone know?  I suppose someone at educate-yourself.org would know, but I have not gotten there yet to ask.  I do know that coils can heal, and the smell of the operating coil is not a bad smell...just very strong and powerful.  (enough that I couldn't sleep with it nearby)  Does anyone know, then, what it is?  Is it just the magnetic field, and that I am sensitive to it?  Is it harmful in any way?
I just realized that smell is the same smell you get when there is going to be a thunderstorm.
IotaYodi
QuoteV= .432  and A= 2.94
Almost 3 amps with less than half a volt? Doesnt look right.
What I know I know!
Its what I don't know that's a problem!
protonmom
Iota,
I just took another reading and this is what I got:
Under Volts...using the (2)      .446
Under Amps...using the (20m)   It finally stopped on 2.96
It started out at around 6 and then kept going down, at first fast, then it took about ten seconds in between each change once it got to the 3's.  Then when it hit 2.8 it started taking nearly 30 seconds to change.  When it hit 2.96 I waited an entire minute and it had not yet changed.
So does that sound right, or is the meter broken, or what?
IotaYodi
QuoteSo does that sound right, or is the meter broken, or what?
I doubt it. Apparently Your getting about the same as Laser. I would like to know if these are digital meters or analog. Im thinking the coil is holding its charge like a cap. If folks are getting 2 amps with half a volt Im impressed. Id like to see a 2 amp load hooked up with a digital clamp amp meter with a hold function already in place, or an analog scope preferably before connecting the load..
I must be missing something here and I would like to know what it is. Its been stated by a few people that digital or analog meters dont work well with NS coil measurements as its a different type of energy being produced. They seem to only work to a point.
If anyone can tell me why the amps are so high let me know.
One more thought. I would like to see what kind of measurements there would be with the coil elevated to 6 foot or more over a 24 hour period.
What I know I know!
