0 Members and 122 Guests are viewing this topic.
protonmom
LaserSaber, I know you are busy, and I hate to be a pest...but could we get a drawing of how you made your coil, and how it is hooked up to produce the energy to run your fan?  Thanks.
jeanna
Quote from: Rapadura on March 21, 2010, 10:18:30 PM
I know my questions are mostly stupid, but I have to ask:
When the coil is submerged in water, and then removed from the water, it generates power during the time that it is drying up, right? For how many hours it generates power?
Another question: has someone tried to connect more than one of these coils in series and in parallel to check if the volts and amps are added?
It needs to be damp so that is the deal... damp.
How long it remains damp will directly relate to how much cotton is there and how wet it was to begin with.
Yes, it works.
But the part to remember is this is a coil which is not a galvanic battery. It has the galvanic element to start it but the coil takes over from then on.
@Conrad,
The question of the galvanic reaction causing electricity and a voltage potential in the wires is not important to me, anymore.
I did this extensively and posted my results ad nauseam and the results are all either here or on Pirate's bifilar coils thread.
Please research these 2 threads for the results you seek.
Or, of course, you could make a coil yourself!
@Pardon,
I have tested my coil with a 1.20 volt battery attached to both the copper wires then to both iron wires. this was a test for the electromagnetic effect. this shorting the 5 and 10 with a battery was the only way i could make an electormagnet. unless i used the 6 and the iron 10 shorted with a battery. then it also made an electromagnet. it may be this coil is just to small its has about 20 feet of both kinds of wire.
what i do not understand is how lasersaber can get a voltage across just one wire in his video he has voltage across the copper wire 5 and 10 and that makes an electromagnet, at least on my wires it makes one.
Dennis
Thanks for finding your notes.
Mine are the same, and I also did the test using an external battery and found an electromagnet.
My only thought on how lasersaber could do the em with just one wire is that he literally hand pulsed it. I used to do this before I understood pulses and it always gave me some reading - even a spark when I reversed the wires! Now, I understand it was the change in the emf caused by the pulse that did it.
So, this is the reason the little cap motor with 4 magnets shutting off the switch works. It makes the pulse happen because it is automatically making the connection or  removing it.
@IY,
QuoteSomeone correct me if Im wrong here. You would get the direct current flow on the bare copper to the cotton. If its pvc insulated your only getting the induced current on the wire from the field collapse and not on the cotton. 2 exact coils would have to be made,one with pvc and the other only cotton,to see if there is a big difference. I think there would be.
It is only a slight galvanic element but without that there would need to be an external battery. This is included with the wet copper wire. It is also likely that there is electroplating that occurs at the end of each pulse which keeps the coil in good repair.
@protonmom,
QuoteLaserSaber, I know you are busy, and I hate to be a pest...but could we get a drawing of how you made your coil, and how it is hooked up to produce the energy to run your fan?
He shows it in his videos.
He made his coil exactly like the drawings NS made right down to the wooden spool ends. It is amazing to see.
He hooked the copper end to one side of the reed switch and the iron to the other end. Only, I think he used the opposite end of the iron wire, but with aligator clips that is easy to try all ways.
thank you everybody,
I am going to find or make a reed switch and try this on one of my NS coils I have here.
jeanna
edit
http://www.youtube.com/user/theDaftman#p/u/15/TSTNVTEqwqg
This is a video where thedaftman does the very same thing.
He uses a bedini bifilar coil and only connects the beginning of one to the end of the other but connects the other wires together. Then he makes his own reed switch from 2 brass plates with an iron washer etc, and when he adds the battery... ta da!
wintermuteai1
Quote from: conradelektro on March 22, 2010, 04:46:18 AM
Wintermuteai1 wants a secondary winding on the Stubblefield coil (I guess as shown in Fig. 4 in patent US600457), the coil placed in the ground (I suppose together with the secondary) and a coil antenna in the air. How should the coil antenna be connected to the Stubblefield coil? May be the coil antenna should be parallel to the secondary? What is a coil antenna?
Greetings, Conrad
Greetings Conrad,
As far as the Coil antenna it is probable that experimentation will have to be done as to how and where to connect the coil antenna. If you examine NBS patent # 887357 you will see examples of coil antenna attached to the "earth battery". You can also infer from photos of NBS. It is my opinion that any antenna should be attached to wires 5 & 6 with the secondary coil to the load, however it is possible that a multiple of ways could be used. It is likely that with an antenna in the air and the "battery" in the ground unknown amounts of current could develop and a spark gap or other devices could be made use of. Since Stubblefield and Tesla were associates, and in looking at Tesla's radiant energy patents it seems likely that Stubblefield came up with a way using this "battery" in coupling with antenna and perhaps tuning coils etc to collect vast amounts of energy from the vacuum/zpe/radiant etc. Since testimony can be read that he not only powered an entire town, radiated from the ground light that appeared as sunlight, and even provided heat to his small home via two polished metal plates facing each other (which were tied in to his device). This is very interesting to note because if you have researched Tesla, you will note that Tesla discovered a myriad of effects when he timed his apparatus via spark gap with an electromagnet(he tried various things even rotating mercury SG). For example:
QuoteTrains of impulses, each exceeding 0.1 millisecond duration, produced pain and
mechanical pressures. In this radiant field, objects visibly vibrated and even moved as
the force field drove them along. Thin wires, exposed to sudden bursts of the radiant field, exploded into vapor. Pain and physical movements ceased when impulses of 100 microseconds or less were produced. With impulses of 1.0 microsecond duration, strong physiological heat was sensed. Further decreases in impulse duration
brought spontaneous illuminations capable of filling rooms and vacuum globes with white
light. At these impulse frequencies, Tesla was able to stimulate the appearance of effects, which are normally admixed among the electromagnetic energies inherent in sunlight. Shorter impulses produced cool room penetrating breezes, with an accompanying uplift in mood and awareness. There were no limits in this progression toward impulses of diminished duration
Therefore, it can be seen that Stubblefield and Tesla both achieved similar results. So we can see that the "earth battery" device is a radiant/zpe collector/converter and that other things such as antenna and tuning coils, along with most likely spark gap with precise timing is how stubblefield achieved the numerous effects that numerous witnesses witnessed at the time.
jeanna
http://www.simplemotor.com/rsmotor.htm
This is a good explanation of what lasersaber is doing.
It looks like a possible source for big reed switches too.
jeanna
conradelektro
A source for reed switches  http://www.meder.com/reed-switches.html
http://www.meder.com/index.php?id=2965&tx_ttaddress_pi1[country]=220 (US representatives)
Can also be ordered from Farnell , order code 1079468  http://www.farnell.com/ (costs less than 1 Euro).
Be aware of the fact that a reed switch can only switch about a 1000 times per second ( 1 KHz). The coil can therefore only swing with up to 1 KHz in case you use a reed switch.
Reed switches also bounce (not a clean on / off). But the massive coil might just absorb the spikes like a choke.
On could build a commutator on the shaft of the rotor that shortens the coil several times per revolution. This could give frequencies up to several KHz but will also cause bouncing (not a clean on / off).
As LaserSaber shows in his video, the little rotor turns, so the reed switch switches the coil somehow. But is this enough to drive a secondary in a useful way? It is worth a try.
An other path would be to go for an oscillating circuit (resonance) by putting a variable capacitor on two ends of the coil and leaving the other two ends open (or shortening them, or putting a capacitor on each of the two ends). But this oscillator would have to be driven by some mysterious earth frequency (harmonic) if it indeed exists. This has been discussed in this thread and did not lead to a solution.
Greetings, Conrad
