lasersaber
The soft iron cores I used were from : http://sargentwelch.com/soft-iron-rod/p/IG0038157/
13mm diameter x 15cm long
They seem to work fine.
I now have my secondary coil working and lighting LEDs.  I will post a video soon
lasersaber
Bruce_TPU
Quote from: lasersaber on April 11, 2010, 10:00:25 AM
Here is the video of the new coil: http://www.youtube.com/watch?v=ZuQGuXJ02fo
Congratulations...very well done!
It would be interesting to see for how long it will run, before needing to be moistened again.
It will also be interesting if more power is garnered by placing it into the ground.
Could you measure the voltage and current also, pls?
Thanks and really, an impressive build.
Cheers,
Bruce
jeanna
Bravo!
Well done.
I got my wire, and I am ready to make this too.
Do you have a scope and can you say that the alu wire works better?
It would sure be nice to use aluminum instead of iron if it really is better.
But, you did make the one with iron, and I wonder if that works at all?
Or, is that still unfinished?
You have really done a great service to the world.
Thank you for sharing it!
jeanna
conradelektro
To LaseSaber !
Congratulations, amazing! Great videos.
Because it will be a bit difficult to have your reed switch and your disk with the four magnets under ground, I attach a drawing showing how one might do it with a solenoid above ground.
But I think you will have thought about that yourself. The trick with the solenoid can of course be tested with everything still above ground.
I would use very heavy speaker wire from the primary in the ground to the solenoid and from the reed switch back to the primary in the ground to avoid losses.
Greetings, Conrad
