jeanna
Conrad,
I think the inner copper and aluminum wires are connected and the outer wires are NOT.
Lasersaber said the connections worked exactly as Nathan Stubblefield said they would, so I think the names on the drawing are not exactly correct.??
Also,
NS said the other wires were to be left open. (the 10's or outer ones.)
Nice drawing, btw.
thank you,
jeanna
Rapadura
Great! Now we have a device that generates electric current from thin air, presumably without consuming any of its parts!
In a cubic meter you can put at least 18 of these coils. How many volts and amps 18 of these coils can generate if connected in series and/or paralel?
jeanna
Quote from: jeanna on April 07, 2010, 02:49:44 PM
Thanks, Bill
Yup,
The next thing I want to do is wrap a secondary around it and look at it with the scope.
This will be run by the 1.2v battery and not a self created galvanism, but it will show me what to expect from the secondary.
jeanna
And here is a very short video showing the led lighting from the secondary of the reed switch motor.
http://www.youtube.com/watch?v=9lspCPpbr88
This is certainly not as exciting as lasersaber's video, but it is helping me to understand the geometry of the thing.  :D
The light is flashing but way faster than this video would make you think.
jeanna
Bruce_TPU
Quote from: Rapadura on April 11, 2010, 07:53:11 PM
Ahh...best to test the "without consuming any of it's parts" first before presuming anything...IMHO
conradelektro
To Jeanna: thank you for your explanation of the primary wire end connections. May be our Stubblefield master replicator, LaserSaber, can shed light on this toppic from his experience?
To all and Bruce_TPU: in case one considers the functioning of a Stubblefield coil as being a galvanic reaction, the wires of the primary will indeed be consumed slowly (by galvanic corrosion). And the anodic index of the metals used for the primary will play a role.
See: http://www.engineersedge.com/galvanic_capatability.htm
From the anodic index one sees that gold wire (instead of copper) and beryllium wire (instead of iron) would be the best possible choice (for very rich experimenters), the anodic difference would be 1,85 Volt.
Aluminium wire and copper wire have an anodic differenc of 0,75 - 0,35 = 0,4 Volt.
Iron wire and copper wire:   0,85 - 0,35 = 0,5 Volt
Zinc plated wire and copper wire:  1,25 - 0,35 = 0,9 Volt
It seems that gold plated wire and zinc plated wire (1,25 Volt) would be a feasible choice for professional experimenters with a budget.
Of course all these speculations are mute in case the Stubblefield coil works in a very different way (not a galvanic reaction).
Greetings, Conrad (a very unprofessional experimenter with a limited budget)
P.S. I got sidetracked by the Joule Thief and its derivatives. It is nice when LEDs and light tubes flare. One has the impression of having achieved something. It also costs rather little to experiment with Joule Thieves (although a big coil for a GBluer-Slayer-Exciter needs 200 meters of thin enameled wire).
