Localjoe
Hey folks its data logging time !!!!!!!!!!!!!!!!!! ;D ;D ;D ;D ;D ;D ;D ;D  one of my favorite times
Id like to compile a spread sheet that included the data of individual stubbelefiled coil replications  and all of their traits.. meaning length and gauge of primiary bifilar wires or weight whatever you used. I also like to include physical dimensions and primary bifiliar coil output  voltage and amperage . For those of us that have wound secondaries please state length and gauge not worried about induced current yet until everyone or at least a few of us has secondaries on there test bed models..
we need some way to actually SEE or calculate the size of the magnetic field and the dimensions it encompasses between quenches/pulses of the make and break in the primary bifilar coil. Also when the speed/freq of the make and break id like to see what happens to the field.  We may be missing out on alot of field lines cutting through if the secondaries arent big enough or the whole shebang inst long enough.. i still think the magnetic field paper that folks use to see the field around a magnet would do the trick for us.
        Feel free to pm me or post your coil data here i will upload the completed spreadsheet after i get a  few entries from folks.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
kukulcangod
GREAT FIND!! This should be remembered as historical as well, giving you credit for it, this stuff is just amazing,i'm dying to know how it was pulsed or wired up to give out power.
On the other hand where can we get cotton   to insulate in between our layers of wire?? I can't find a suitable source! any suggestions?
I tried but i can only find crazy stuff from macy's!! any help will be apreciated.
10 dollars...unbelievable ... I've been trying to locate and item like that myself ...well right now I'm really away from the states so that search was over a while ago. I'm trying to come up with ideas myself as to how to get more power out of this, so the last post are right along my thoughts and are much appreciated, in my humble opinion this is the type of stuff that can change the world forever and for good, let's keep trying ,for one I will keep fighting for it I promised a long time ago , specially when in my case seems destiny that put me in the way to it...
Use the lincoln welding rods r60 copper covered steel alloy for your cores, it is the same bedini uses for his coils for high frequency switching, obviously the idea of using a transistor it is a must, remember that this works are on the lines of not just Mr Bedini of Tesla but also Don L Smith, it is all about high frequencies and resonance...
Good luck to all and most of all I thank you all for your feedback and willing to share this wonderfull ideas and discoveries
alchemist123
Ill look through some textbooks to see if i can find something that can determine the size of the pulses/flux.   I do remember something though about a magnetic fields strength decreasing to a quarter strength when you're a radius away from the source.  For example: for a 2inch magnet with a 1T field strength, the amount of flux that is one inch away from the magnet is only .25T
How does anyone propose making the primary and secondary resonate if it is even possible, 3 different kinds of wire with different capacitance and inductance?  Anyone fill me in?
Also I agree Looks alot like a transformer,  the core looks to be all in separate little sections, and the shape is consistent with a transformer with the interior being larger than the legs
jeanna
Quote from: kukulcangod on May 12, 2010, 02:18:33 PM
Really any thin cotton or silk fabric works well. gause has holes that are too big, but ultra thin cotton or silk is great for this. It just takes longer to wrap it while you wind, but it is how I made all 13, well 11 of the galvanic ones I made.
QuoteUse the lincoln welding rods r60 copper covered steel alloy for your cores, it is the same bedini uses for his coils for high frequency switching
Thanks for the tip.
I have no more excuses now, I will build one on welding rod.
:D
Quote, obviously the idea of using a transistor it is a must,
It works with a transistor.
I used it as the toroid of the joule thief and it works.
Now, it needs to be its own battery for the final job using a transistor, but I promise you it works.
Thank you k-k-god,
@jim
Amazing find!
Please do me a big favor.
Take a few threads of the cleanest cloth there, and light them.
then take a whiff of the smoke.
Does it smell like wood burning?
I wonder if that resin is lac from the lac beetle, or polymerized  linseed oil or maybe pine sap resin?
That might be interesting to burn too.
jeanna
