Artic_Knight
The current produced is highest when the two metals are most widely separated from each other in the electropotential series, and when the material nearer the positive end is to the north, while that at the negative end is towards the south. The plates, one copper and another iron or carbon, are connected above ground by means of a wire with as little resistance as possible. In such an arrangement, the electrodes are not appreciably chemically corroded, even when they are in earth saturated with water, and are connected together by a wire for a long time.
It had been found that to strengthen the current, it was most advantageous to drive the northerly electropositive electrode deeper into the medium than the southerly electrode. The greatest currents and voltages were obtained when the difference in depth was such that a line joining the two electrodes was in the direction of the magnetic dip, or magnetic inclination. When the previous methods were combined, the current was tapped and utilized in any well-known manner.
In some cases, a pair of plates with differing electrical properties, and with suitable protective coatings, were buried below the ground. A protective or other coating covered each entire plate. A copper plate could be coated with powered coke, a processed carbonaceous material. To a zinc plate, a layer of felt could be applied. To use the natural electricity, earth batteries fed electromagnets, the load, that were part of a motor mechanism.
it would appear that we are following this verbatim. so in that respect, shall we try an electric motor? i would imagine a special electric motor with an iron core at the windings would be most effecient for pulsed dc and usually not hard to find (old style from rc cars)
Artic_Knight
i just looked at stubblefields wound battery and its very interesting, we are dealing with what scientists think is magnetic currents (doubt that since magnetic currents have to move to generate electricity) whats interesting is there is an iron bolt through the middle, a coil of wire around that bolt and another coil around that coil (the two coils seperated) it looks like the bolt is intended to be exposed and if thats the case i would like to see it aligned with the bolt tip to top north to south. so the magnetic current flows through the bolt :D what do you guys think?
i bet i could get away with that here :P  i think ill try it :D
jeanna
Hi Arctic night
Quoteso the magnetic current flows through the bolt  what do you guys think?
i bet i could get away with that here   i think ill try it
yes, please try it.
I just got up to speed here. I apologise for the uninformed comments I have made.
I think I stopped looking in around the time that rude guy was around.
I will be away for a couple of days.
But i will check in on thursday
and yes, please try it.
Bill,
I watched your videos. I think I get it. It is an interesting and beautifully simple circuit. bravo!!
I will try some of this when I get back.
jeanna
nightlife
 You all should read the comments from the "What is elctricity" thread in the half baked ideas forum. My conclusion may have the answer to your problems here.
Localjoe
@nightlife
     I like your ideas man but unless they directly apply to your exp it doesent help much.
Ok folks when i said they could be connected in series... i ment additive voltage but not in the hookup sense were use too...  as opposed to putting carbon to zinc then carbon to zinc making 2 cells
only connect one lead from 1 of each metal to your load.  the reamaing copper or zinc in the ground connect to other metal of the same so for instance copper to copper to load and zinc to zinc to load thats what gave me the results... sorry for not being clear earlier... Ive had a lot going on. And as far as anyone devolping a device similar.... Its open source keep it that way, and if you try to patent it i do have lawyers in the family.... this shit is staying free .   I had a guy recently messge me and ask why i didnt want to patent my camping device idea to make money...  And i told him once its finished and compacted.... its going to be freely sent to as many places as i have time and money .  But at no charge... ususally has the effect of people being happy and sharing... Hopefully all works out well.  all i have to say is if you could charge your phone ipod ect anywhere you could stick this thing in the ground ... and have a light... it would cool real cool.  Dam you mintyboost for starting a revolution.
        Joe
PS at this point were still dealing with replications not fine tuning so any of the frequencey ideas i would appreciate if left till later... once  we have the basics then we can use coils and all there inductive properties. But for now we need to find our best arrangement of electrodes and determine if the amperage will be high engough to run the boost circuit. Thanks again folks.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
