0 Members and 149 Guests are viewing this topic.
the_big_m_in_ok
Quote from: IotaYodi on May 17, 2010, 01:10:24 PM
A question I have is how the radiant energy interacts with the earths magnetic field thats coupled to the coils magnetic field.
To pose a wider theoretical question?
What effect does radiant energy from the universe at large have on any atmospheric wire collection system, or also any earth battery system?  Taking either of these to the bottom of a very deep mine would have what effect in power output compared to surface readings?
--Lee
Mk1
@all
Earth magnetic field is a constant , and usually can be ignored , because nothing on earth is without it , magnetic and gravity are a couple working in symbioses weight of objects are related to location not the objects ... (weight less in space yet nothing changed in  the material structure )
This means that anything in relative proximity of earth is filed magnetically and statically , now the kick is most likely explained by the introduction of a second field in mater of electrical source that causes a violent reaction in mater (core even wire) .
All that being said , kapanze uses a radiator to pick up radiant energy from the ground (radiator/radiant lol).
This is the only way it makes sense ...
IotaYodi
QuoteEarth magnetic field is a constant , and usually can be ignored
There is a constant field but the field changes intensity and direction. I dont think it can be ignored as far as the NS coil goes when in the ground. Without a magnetic field there can be no current. Without the on/off of the current flow there can be no bemf which creates the radiant energy in the coil.
What I know I know!
Its what I don't know that's a problem!
Mk1
Quote from: IotaYodi on May 17, 2010, 06:00:24 PM
Yes the coil is on and off  ;) , but that changes nothing to earth magnetic field , it is still on regardless of the battery or coil being on or off ,the constant is earth field not the coil ...
That is why it is most certainly ignored in usual electronics , it doesn't mean it is not there , all i am saying is that its always there and would most likely explained the physical reaction (bemf) it is like trying to fill a bucket of water that is already full (earth field)...
So the wire already is full , and adding more only disturbs the standing earth field.
jeanna
Hi everybody,
What I don't get is why we are still talking about this as though there was still nobody who could make this.
Why doesn't anybody else want to make one like lasersaber's?
I am doing that to the best of my ability.
I can and will fool around with it later... after I get a copy working.
I was having trouble getting the reed switch motor to work and if I cannot get this, I will be forced to take apart the little kit I made. I will do that if I must, but really, I think lasersaber understood this and has shown us how to make the NS generator work.
Lidmotor and I have not been able to follow.
Are there no other takers?
jeanna
edit
Lidmotor just posted a video where he uses the slayer007 sec exciter to his stubblefield generator with only 1 wire.
This is probably about using it as a receiver and antenna.
I found mine to be a good receiver, some might recall.
http://www.youtube.com/watch?v=FzGjjG41k4s
