Mk1
@all
If there is a proof that it is fake i wasn't to hear it , but in Nathan words
Stubblefield called the New York promoters a bunch of "damned rascals." He said they were "defrauding the public." What he meant was that they were defrauding his dream of unlimited voices, for unlimited distances, and unlimited lights. The mystic of radio with his loops and coils and magic was being defrauded; and all he wanted was to make the aether speak.
It is mentioned light ...
The way i see it is a type of bemf in ground it self , propagating for close to one mile around .
http://www.ralphmag.org/stubblefieldU.html
I said he lived 50 years before his time , i would say more like 100 to 120 ...
http://earlyradiohistory.us/1902stu.htm
http://www.fantasticforum.com/1res/printthread.php?s=724b64754fa7643fd1dcfbbb86b175ea&threadid=12061
IotaYodi
My opinion is that someone already here made that drawing. The moderators would know that. I just see it as a modified drawing and not fake as there is no patent number or anything else. Someone was still thinking and thats a plus..
NS didn't have reed switches but he did have magnetic fields. Lower spark voltages produce higher magnetic fields while a certain spark voltage causes the highest magnetic field.
http://sciencelinks.jp/j-east/article/200320/000020032003A0644964.php
It may have been a simple matter of an iron trigger coil placed near a spark gap. You wouldnt need a magnet wheel or a reed switch. This needs to be tried out.
Notice the wires that are coiled in the picture. The wire wouldnt need to be coiled unless there was a purpose to it. That purpose may have been for the magnetic field.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magcoi.html
If I remember right Voltage spikes charge a cap quicker and better. Someone correct me if thats wrong. The bank of caps in the picture are manufactured caps and not home made.
We may need to take this to a higher level with a specific site for serious research on this coil. Meanwhile Im about to be surrounded by oil. I cant tell you how irate I am with Corporations in general.  :-[
What I know I know!
Its what I don't know that's a problem!
alchemist123
The photo you have is interesting mk1, lots of large capacitors wired to the batteries.   I think it was a way to store the high voltage ac generated from the secondary.  The coiled connection may have something to do with impedance ( in this case inductive reactance ) which would have an effect on current, being that ordinary capacitors have low capacitance I think it would be safe to say this was a means of current  limiting.
Also in regards to the questionable drawing,  its someones interpretation of what the lasersaber coil is all about not an authentic stubblefield drawing.
Cap-Z-ro
I noticed the the wires attached to his steel rods were also coiled...possibly for ease of handling.
And IYoda...all you have to do to protect your shoreline is to toss copious amounts of ordinary straw into the water...the oil crude oil will stick to the straw, and you just scoop up the straw and oil all at once.
Thanks for those great links Mark.
I one the following really interesting statement was attributed to NS...
' This earth cell can be greatly magnified. Its discovery was the beginning of my experiments with wireless telephony '
Also he said his son Bernard was quite capable of carrying on his work should he die.
Someone in his family may have some helpful information...although one would have to tread carefully, as there were a few family members who sued him.
Regards...
Bruce_TPU
Good evening ALL,
I had a strange thought experiment this evening.  I have just concluded watching the fifth video by Lasersaber on his NS replication.  http://www.youtube.com/watch?v=jLL7YKO7q8c&playnext_from=TL&videos=udkQIxrHYrQ#
And I posted the following comment to him, and before "ruling it out", I just would like each of you to think through it for a moment.  It is an interesting thought...
Posted Comment to Lasersaber:
"I think you should attempt to feed the current from the secondary, BACK into the primary. This would in turn, make the secondary stronger with more current, and this would then be fed back into the primary, which would make the secondary once again stronger, etc.... You get where I am going with this..."
Thoughts please....
P.S>  I think that "FEEDBACK" may be the secret that is missing...  ;)
Cheers,
Bruce
