0 Members and 133 Guests are viewing this topic.
Bruce_TPU
Good evening ALL,
Groundloop spent a great deal of time, making the following diagrams and cleaning up Aaron's circuit drawing, to make it much easier for experimenters to experiment with the feedback/recovery circuit.
THANK YOU Groundloop for your hard work!
Cheers,
Bruce
Mk1
@all
Lol , now we need a 555 ? Not good .
Just take the regular joule thief circuit , i would try 2 things connecting the base to either an additional coil or to the core via a diode .
If there is a additional coil connect one end to the positive of the galvanic battery the other to the base of the transistor. Or even try a none connected base exciter type .
Please no 555 or additional battery .
Mark
jeanna
Thank you groundloop!
This is a beautiful drawing. It is clear etc.
I am all for the pulse motor with led on secondary.
I also think the motor can be strong.
John Bedini has made strong motors from something like this.
About Aaron's ideas,
I am not ready to enhance my NS coils yet since I have yet to make mine work as described...(but that is coming soon.)
We have not explored what the patent describes, yet.
Of course there are always bunches of folks who like to jump ahead, so this is a great place to experiment, and a great direction. Aaron has spent a lot of time experimenting with these.
Quote from: Mk1 on May 23, 2010, 10:35:23 PM
I agree with you Mark.
these are my best bet for the first stage.
I think since we see most of the pictures of these coils in pairs the evidence is strong that they work in pairs.
And, I also prefer the joule thief for my pulse generator.
And besides, I honestly believe that this IS a joule thief with an inherent battery and a mechanical switch.
I kind of want to give Nathan Stubblefield as much honor as I can for making this remarkable invention.
I have mentioned this before and I will now post a fuzzy picture of a joule thief circuit on a breadboard which is using a Stubblefield coil for its magnetic induction.
Another way to say it is this is a stubblefield coil being made to work with a transistor instead of a reed switch.
the light is at the C-E
The secondary produces about 40v
Sorry about the fuzz...  ;)
jeanna
Pirate88179
Jeanna:
I agree with you 100%!  With what I have learned here on ou.com over the past years, I have to agree that the NS coils IS a early rendition of the JT circuit.  It is all related as we suspected in the early days of our research.
This is going to be good.
RudyT
I may have found a supplier for cloth covered wire.  Found a chinese company that said they can supply me with 1500 feet spools of cotton covered galvanized steel wire 20 gauge.  thought why does the copper have to be covered why not the steel :).  will post more when i find out more information and actually try to make one of these batteries.
