0 Members and 133 Guests are viewing this topic.
conradelektro
Thank You for the encouragements  ;D!
I admire the many mixtures discussed in this thread, being mentally very far from chemistry. May be alchemy attracts me.
Attached see two photos of a long running test I set up with the "copper - tile cement - aluminium" cell and a low power Joule Thief (the also interesting circuit with an air coil can be seen in a recent post in the Joule Thief thread). The idea is to have this thing (a red led driven by the cell, pretty boring) sitting around in my house till it self destructs. One just has to glance at it occasionally to see whether the little LED is still on. Only once the LED is off one has to do something (like looking for a failure of the circuit or the cell).
In defense of the commercially available frost-proof tile-cement: It sticks to about everything very well (including metals, even skin) and takes heat, cold, dry and wet for at least 30 years. And it is in essence just "concrete". So initially the bond between the cement and the metals is excellent. And if there is a chemical reaction on the metal it should fall of the cement eventually and one should see a layer of stuff. I want to keep the cell dry (at the atmospheric humidity of my house throughout the seasons).
A strange idea (definitely not new and not originating from me):
Reading through this thread and watching many good and bad videos on YouTube about "crystal cells" it came to my mind, that most of the cells shown and discussed (in spite of a multitude of ingredients) produce about 0.15 mA (with some little variations up and down) no matter how big or small they are. I am intentionally not very precise with this statement, but there are no small cells giving 10 mA (withe a size of 10 mm to 100 mm) or really big cells (e.g. one meter wide) giving many Amperes like bigger commercial batteries.
For me (knowing less than nothing) this points away from a pure chemical interpretation of these "crystal cells". I will therefore go into the "multiplication" of a very simple cells (why not the "copper - tile cement - aluminium" cell, because all the materials are readily available).
By "multiplication" I mean a setup or arrangement of the elements in a way that one gets (automatically) many cells in series and parallel (hundreds, if not thousands). This is a geometry problem, a way of producing very many cells in a clever way to avoid too much manual labour or complicated machinery.
I am thinking about "brushes with many bristles", "nail beds" or "combs". Once I have something set up you will hear from it.
Something from the environment could be soaked up by these cells (heat fluctuations, electronic smog, magnetic currents in the earth, static electricity flows in the atmosphere, even neutrinos from the sun or the overused zero point energy). If this "soaking" is part of it, one wants to try a lot of "receivers" instead of one "big receiver", because one "receiver" might only "soak up" a tiny amount of electricity mostly independent of its size.
Just dreaming and speculating.
Greetings, Conrad
conradelektro
Sorry, my last post should have gone into the thread "Crystal Power Cell by John Hutchison".
Having too many windows open on the screen is not such a good idea.
Greetings, Conrad
Mk1
@all
While reading about NS , i stumble up on Bedini site on the information , that
Tesla was quite taken by the NS invention and decided to develop the most efficient version , reading about Tesla and NS made me realize that when they talk about the energy from the cosmos and pumping it , we don't recognize it today , but its the galvanic pump ...
Look at this drawing , back in those days wires cotton covered wire was a standard thing . Look at the connection , it is the same as NS ...
Look it even says electromagnet , one iron wire and one copper covered coil connect them like the schematic , and voila one electromagnet .
the Pancake coil at the bottom of the Tesla coil , same thing the power is with in , raise it high enough to get a kapenze to spark ...
Mark
This is so cool ... This is a renaissance , the intelligent design power by design included in the circuit ... ;D
Bruce_TPU
Quote from: Mk1 on June 09, 2010, 06:11:12 PM
@all
Mark
Hi Mark,
A very, very interesting idea, indeed.  Thank you for sharing it.
Cheers,
Bruce
Pirate88179
@ All:
I have received a note from Jim (electricme) and he asked me to pass on a message.  He has been tied up with tornado damage down in his neck of the woods and also, his satellite dish is still limiting his connection speeds to down below that of dial-up.
He is fine and will be posting here with us as soon as he can.  His cotton covering wire machine is working well and he has obtained a very large roll of cotton.
