0 Members and 18 Guests are viewing this topic.
FrozenWaterLab
Quote from: Pirate88179 on August 08, 2010, 01:48:48 PM
Frozenwaterlab:
Nice work.
You dip angle for your area is what you use to figure the depth of your electrodes not the declination or inclination I believe.
Hi Bill
Have enjoyed learning by watching you and Jeanna and Rob Et All
I think its just that you havent looked at the site for a bit.
This is my read from the NOAA site for South-Central Alaska
8/8/2010
Lat:   61° 34' 49''
Lon:   - 149° 29' 18''
Elev:   0.00 m
Declination
+ East - West   19° 6'
This means if I'm looking at the Mag North (Aprox over the great lakes)
I must look to the left 19° to look at the Geo Pole
Inclination
+ Down - Up    74° 31'
This one is much more difficult. I believe has to do with how the field lines come out of the ground. I admit my knowledge is sketchy in this area.
(Any of you seen Howard Johnson's work? He plotted the field lines of a Magnet. NOT Like the metal fillings - They are each a magnet themselves. Magnets field isent as a Circle it's a figure eight. There is a BLOTCH WALL in the middle and both the North field and the South field enter it. In fact both N & S flux lines come out of and enter both ends.
Check out Beardens sight and order BOTH of Mr Johnson's CD's
He's the inventor of Spintronics.
Anyway, if on the equator level placement and as one progresses towards the pole the northern electrode must go deeper until you stand on the pole itself where one is over the other.
   Say where's the GEO Guy anyway?
And, using trig which I suck at, you can manipulate that depth by the spacing of the electrodes.
You are right - Must be a math formula for it.
I just hold one of those half circles upside down.
0 to right North
180 to left South
90 at bottom - Then shift 16 degrees to the right towards 0 (Aint much)
   Mg 1
         1
           1 Carbon
Without the formula I'm taking a stab at 1' seperation for 3' deep
Now for the 8' Grounding rod I'm guessin 2'6" to 3' seperation will give best reading
If I just wack 3-4-5 in a row every 6" and take the best should let us know, Right?
I would be very interested to see some power readings from your experiments.  Don't be alarmed if the meter sort of counts down from when you first apply it.  Mine has always done that and I think it is because the meter (on mA setting) is kind of like a direct short to your system. Once you remove the probes and then reapply them, it should go back up to the original value and then begin counting down again.
Ya I tried in the rain but couldn't get anything meaningful.
You Guessed it FUSE Will get replacement
My last readings quite a while ago were in the 19 ma area but, with my 5 pound block of magnesium encased in that bag of stuff (Like what you had posted earlier) should be giving me over 1 amp according to the tank grounding instructions that came with it.  I probably need much larger carbon area to do this.
I have one of them from a ship hull - I'll go take a pic
this thing weighs 16 lbs but there is a 1/4" x 3" x 6" iron plate in the middle
I need to put togeather that mix for myself (Got Cats - more to the mix WHAT :D)
improves ground contact - I'm on it.
I've Wound my first JT
I have some various size LED's and have wound a JT 2.5"dia 1/2" thick
Sec is 3 layers about 100 turns ea. of 26 gage.
2 ea. - Pri wound on top 1-10 winds 2nd-20 winds, both 22 gage.
Will be playing with that soon.
I want to build a Pulse Motor like Lidmotor has.
Read switch firing NEO rotor on Magnetic bearings against a coil hooked to EB
Like done with the NS Coil
Looks to be a good experimental LOAD.
Rev Counter should give an idea of power available etc
Best of luck and keep us posted.
Tnks Bill and You Bet. I'm building one of jims Cotton winding sheans
Wana crank out the NS Coils (Got two 3'x1" old Iron Bolts)
But yaknow NS said his bolts would become saturated with the Mag field and need replacing.
I wana try different corres But rep Pattent first!!!!
Some one was talking about switching both ends of the primary at sequential times.
That should scramble the remenant magnatisum???
MOre reading. Pg 161 now when I get home tomorrow from the Dr.
Quote electricme
@ everyone reading who also keeps an eye out on Chemtrails.
A new way or method has been found by the baddies, to spray us all with.
@ Jim
Hay Known about this for long time
Ck this http://www.cheniere.org/clouds/index.html
Got Pics somewhere on my computer of the tanks in the aircraft belly
and pics of the nozzles etc. I'll look for them and Personal E-m them to you if I find them.
Bizzare aint it.
Don't squack too loud dangerious aint nothin can be done I know of.
I sure aint takin there shots though.
I find your experiment very interresting
Have you been able to keep a flowing record of your results?
Jim This is the beginning of my actual experimentation. In the EB area.
I have been studying and learning for 4-5 years now.
Started when told I couldn't make enough HHO to be worth while.
Bull out and out. Made a cheep setup that paid for itself in 1 summer of fuel savings.
Did a little Joe Cell - some Hull Effect - Made a 700kV Vandegraff etc etc
FUN STUFF (My Wife is in Thailand so I have to keep myself busy.)
Wana help ;') Were in trouble and most don't know it. We need this info for later I think.
I have a Badini wheel I want to try to run with the NS Coil if possable. Thats my long term goal.
Wee hours commin on fast - Gotta up early
FrznWtr
electricme
@knabe
Welcome to the stubblefield coil forum, and it's nice to have you along here. ;)
On the topic of series electrodes in the earth, been there and done that,
I had 63 by 7 inch (each tube 1/2" diameter) copper tubes filled with dirt with a 3 inch zinc nail driven into the center of the dirt in each tube.
I forget how much voltage I got out of it, from memory, somewhere around 66 volts DC in milliamps, I ended up connecting the whole array in series parallel, it was enough to run a single white LED very brightly for around a year. (I burnt out a LED)
I had to keep topping up the dirt with water, sometimes 4 times a day in the middle of summer.
To get this cell array to work, I had to wrap insulating tape aroiund the outside of each cell, and seal off the bottom else the electricity seemed to leak out of the bottom of the cell interacting with all the other cells.
Beleive me, it does work, but you would need square meters of materials in each cell to get grunt outa your earth battery array, and I couldn't afford it.
Actually Bill (Pirate88179) has had better energy out of his 2 carbon and Magnesium electrode setup.
jim
FrozenWaterLab
Quote from: knabe on August 09, 2010, 03:11:33 AM
One more fact about series.
I did make a earth battery from aluminium and copper foils. Both were 210mm x 3m. I rolled them in a roll with cloth between the foils. I made four pieces of them and buried one in one hole and three together in another hole. I connected them all in series and got more than 2V DC and .6mA. So, if the electrods are not exposed to outside, they work in series very well.
Place is relevant even with galvanic operation. There are grounds, who do not keep moisture. You can add water, but it goes away fast.
You must bury deep enough. In winter, when earth freezes, volts and amps drop by half and more...
It is good to have a bunch of cheap analog multimeters. First - they do not need batteries to run. Second - you set one to volts, another to miliamps and can easy see how your system operates. Good choice for monitoring output for a long time.
K
All good info Tnks Will try replication of info. Eventually when enough reps we can say:
Put this their and so far apart and do this that etc.
I was looking for that info for some time and it was not forthcoming. Experimentation.
Many minds focused will illuminate the answer. OPEN Source.
Go back to the time this thread started and consider what we have now. It will get better and better.
FrznWtr
kukulcangod
Electricme
                  I wonder, how much power you thing can come out from a battery like the one you unhearted at that farm? , are you planning to make bigger ones in series parallel ? Have you found more info in regards to it?? I hope you can tell us before going on your vacation, other than that enjoy it and recharge that brain !! I'm sure you will come back full of inspiration anyway.
lbnc392001
Hey everyone, i have followed the thread with intrest since last year and found there is a company working on sending electricity wirelessly using magnetic resonance frequencysimilar to what the earth produces naturally. Something to think about as you all experiment. The company is wii tricity and here is the wiki page address.
http://en.wikipedia.org/wiki/WiTricity
