0 Members and 28 Guests are viewing this topic.
Mk1
Quote from: jeanna on August 29, 2010, 03:21:26 PM
@MK1
I am following the instructions from lasersaber, because his works. In fact, he has many versions which all work.
Here is why:
The moment the magnet from the rotor passes the reed switch, it will close it and then the battery will run, but then the magnet moves away and the coil stops producing a spike.
This will work with either type of reed switch as long as I am willing to start it.
Please remember, his thread terminally stalled when we could not find a 'n-c' reed switch a couple of years ago. Lasersaber restarted it with his instructions, and I am happy to try them.
I hope it will work , my guess is you are using the exact same switch as lasersaber .
Otherwise , look at the switch specs , i know no one had that problem yet but that doesn't mean its not there , even more because unusual problems are usually fall on you ...
I don't think that if it worked for others it will work for me without specific spec , is the most efficient use of time .
All i know is lasersaber puts the wheel on and it starts running , that means the coil is one and get turned off at the switch , also the polarity of the coil and magnets have you tried both ends of the coil ?
Mark
FrozenWaterLab
Quote from: Pirate88179 on May 21, 2010, 01:46:42 AM
Mark:
We have other information and I am afraid the photo /drawings are faked.
Hello All
I'm still reading and am on page 232 so forgive me if this has been discussed already.
Concerning the Double coil Pic
I think it is a recent production BUT Who ever did this put allot of thought into it.
I have read an opinion that it is from Lasersabers work. Maybe - Maybe Not
Has anyone studied the Great Briton Patent? I see NS stated that the 5&10 or 6&10 may be connected (While the opposing pair is disconnected) to induce the Magnetic pole direction one would like to have in the core.
Has anyone else noticed this? I think it would be wise to search far and wide the world over for any thing he submitted.
This is not explained in the US Patent. May be that some other paperwork may be available that would give more clues.
I havent finished studying the GB Pat yet and am interested if I might see something else.
Oh it dose say something about Mika for between the primary and secondary.
I found Flexible Mika sheets on E-bay - made in Poland (Shipped from their anyway)
http://cgi.ebay.com/FLEXIBLE-MICA-HEAT-RESISTANT-INSULATION-10-SHEETS-/320531418073?pt=LH_DefaultDomain_0&hash=item4aa1294bd9#ht_591wt_913
Anyway I think serious thought should be given to atempt this replication.
Someone in the know may be giving out info????????????
FrznWtr
What I can see in both Pats
US Pat
The terminals 10 of the copper and iron wires
5 and 6 are disconnected so as to preserve the
character of the wires as the electrodes of the
20 voltaic couple; but the other or remaining
terminals of the wires are brought in contact
through the interposition of any electrical
instrument or device with which they may be
connected to cause the electric currents gen-
25 erated in the coil-body 4 to flow through such instrument or device.
It will also be obvious that by rea-
son of the magnetic inductive properties of
the coil-body 4 the core-piece 1 will neces-
sarily be magnetized while a current is go-
ing through the body 4, so that the battery 8o
may be used as a self-generating electromag-
net, if so desired, it beingg- observed that to se-
cure this. result is simply required connect-
ing the extended terminals of the wires 5 and
6 together after wetting or dampening the 85
coil-body.
As oposed to in Great Britan Pattent
Read the first Paragraf
See .rtfd (Hope it shows)
FrozenWaterLab
Whale I'm posting maybe I should put down some thoughts.
If the coil were to produce cold electricty (Who knows at this point)
I know the spark gap WILL - Tesla knew this and I'd bet he mentioned it to Nathan.
Radiant Energy Can Be collected with Bifalar Pancake coils on all sides of the spark gap and run to caps,
both from coils and from output.
Thats the direction I'm going to be headed.
Now weather the read switches or a vibrating set of contacts. This is something I've been pondering.
The read switch is going to run at the speed the wheel turns. Not necessarily what the earth field is running at.
if their were two contacts above and two below a copper to one and an iron to the other both top and bottom - with a bar on the vibrating arm and a small magnet attached to the arm.
When up connect contacts for set of wires for direction of coil to draw arm down.
When connecting down makes direction of coil to repel the arm up.
This would vibrate at the power that the earth currents want, wouldn't it?
At least their is a chance for that type thing to occur.
This also could be run in the duel coil mode. (Just love that concept)
I bet above that spark gap one could put a Tesla Hairpin.
Just thoughts.
FrznWtr
FrozenWaterLab
Well I'll be darned. About the 3rd post I read after my post. There it is By
Master_T in post 3476
Definite good Idea Master_T. How do you progress with that setup?
Well I'm back to reading - I should be with you all soon.
FrznWtr
