electricme
@mw383
Hello, nice to see you again, thats quite a break you had  :D
I heard the groooooan down south here as you realised playing catch is fun fun fun lol.
As Bill says, lasersaber has done some big discoveries, and more will be coming forward no doubt.
jim
MW383
Just got done watching lasersaber videos. Nice construction techniques with results similar to my last attempts last year. My interest in this subject is becoming very much renewed.
I am going to start with a few ground experiments using the series-parallel-resonant induction circuit + pancake coil apparatus I have. I posted a picture of it last year I think. (Coil in the picture was for another experiement and will not be used for my ground experiements. That coil was a water heating system. Coil wrapped around ferrous iron pipe. It was one hell of a water heater btw.) So I'll be using pancake coil that I have. It will be mounted vertically in ground so that it creates a field in a rough N-S orientation. Coil has mumetal on 1 side thus quenching field in that direction. I will run coil with+without the mumetal and see what happens. I can run the coil at various power levels and 2 frequencies (50khz, 25khz). The circuit does not allow me to do much else but I will see what happens anyway. I'll probably put some rods in the vicinity of field I create and measure any variation in earth electrical response. Probably simple copper-iron deal here. Will not be able to get iron near field as it will heat. I'll play with it. Results by next Monday...
dllabarre
Quote from: MW383 on September 23, 2010, 11:15:43 AM
If you have that old picture handy I'd like to see it.
If not, I can wait for a new picture after you get set up again.
Thanks
DonL
MW383
Quote from: dllabarre on September 23, 2010, 11:35:12 AM
Thanks
DonL
http://www.overunity.com/index.php?topic=7769.msg210889#msg210889
Here is link for page w/ picture. Water heating coil present in this picture. (induction water heating...) On a side note, I have new litz wire so I can build improved water heating coil that should be better than original one in picture. Call it an ultra-modern (and very efficient) hot water heating system for your house...That is the intent anyway. Could also be used for domestic hot water but only in low output flow/volumes. Induction circuit requires only 450W/120VAC so feeding it with small wind generator feasible. I live in extreme wind. But this is off topic :)
For ground experiements I will be using pancake coil mounted so that field produced is in line w/ natural earth magnetics for my location as reported by that one geological site. I have to re-look up but as I remember it, the field ran slightly SE to slightly NW by a few degrees from true N-S and at an inclination angle of 12deg downward as it heads to the North. Again, I need to find that site and look this up again. When I was experimenting with simple Fe-Cu rods, my best results were obtained when I had rod alignment tuned to geological data for my area. So with my gizmo, a magnetic field artificially being produced and in-line with earth's own. Circuit limited to 25or50Khz unfortunately... Field will be quite strong however. My question is...what is happening electrically on axis to right angle of this created field? Fe-Cu posts will be re-employed. Readings of their output will be taken in natural state and when artificial magnetic field activated. These are some basic questions I have after reading many geological prospecting patents (looking for oil/minerals) in which a similar technique is used. This type of equipment employed in 70-80's and able to react with earth to great depths.
Whole theory here is that natural system balances itself magnetically/electrically. We know natural magnetic field is there. We know there is electrical counterpart through simple Fe-Cu rod experiments. We know the electrical response is weak (say 1 volt and 20ma DC). So it would seem reasonable that magnetic field is also weak. In looking at the magnetic field data for earth, it is stronger and weaker in various places. Thus I would expect stronger/weaker electrical responses. Stubblefield seemed to have a knack for finding the best places to put these things. It would appear that rock-ridden ground doesn't work so good as evidenced in a Stubblefield failure up in New York if my memory serves me correctly. Maybe all of the rocks create localized or larger dipole effects that screw things up, not sure..
My basic question = will earth respond in larger electrical way if larger magnetic field present? Hence I will get busy finding out. Should there be anything interesting here, better-more adjustable equipment will be needed. I want to go much lower in frequency than this circuit I have. I have found various kits that can be constructed together to achieve this. I need to find all of that info and review again. I also want to experiment with the many parallel-resonant Tishitang ideas posted here last year. Stubblefield did radio and it was probably a closely related to his battery in ways. Thus I still think Tishitang's thoughts still apply to our work. On another note, the construction of Stubblefield's coil is brutal. Maybe low in voltage but should handle some real big current. I have to think it is built big for this very purpose. We get mA DC out of what we currently build, Stubblefield looks to have had much larger current and at some frequency related to earth's.
But how to get it :)
shylo
Hi to all am new here and have been trying a few things ....I'm currently reading this post from the start,on pg28 so far.....posted about putting a mini NS coil in series with copper &galv pipes ....their voltages added...Just tried to hook two coppers, to two galvs, they won't add ......I seperated the two coppers by 10'.....went 15' to the south .....put the two galv spikes 10' apart....I can hook ethier copper to ethier galv ...and get the same readings 1.03v.........tried adding in series and parallel.....neither worked.......read that somebody isolated their probes with plastic.....this allowed them to add .......I tried house wire 14/2..taped the ends that were in the ground.......didn't work.......I'm sure the answer is there just have'nt got there yet.......can anybody save me alot of reading.......maybe an update of what works and what does'nt ........thanx in advance ......shylo
