0 Members and 189 Guests are viewing this topic.
electricme
@shylo,
WL = 90mm this is the single turn length of wire, by doing it this way I can put the measurement into a software program I made and it will tell me the total length of wire I used on just that layer, eventually it will tell me all the turns on the coil and length of wire  consumed.
One day I will get around to modifying it to work out weight of copper and Iron used.
Could you please draw your coil and post it here, I'm having difficulties understanding how you made it.
There are just a few more posts made since you last read the forum. I have a couple more to post myself after this one.
jim
electricme
@MW383,
Quote from: MW383 on October 22, 2010, 11:23:24 PM
Jim, wire is 16ga which should be .050", i measured and it was more like .048". With the fiberglass insulation, outside diameter is near .060".
I will force feed it with various electrical inputs. it will be smashed and bashed and observed of course. I'll try every theory presented in the 250+ forum pages here, especially Tishatang's. But many others too.
I say beat the hell out of it with various inputs and see what happens. What do we have to lose?
Best wishes... MW
Thank's for the wire sizes, I think it will be 0.48 thats tiny isn't it, well lets see what it will produce when made, yep, give it a hideing, thats the way, flogg it to death.
A half inch X 12 in core should be OK, BTW, I recomend you make a winder for it, my MKII machine here is working sooooo good now, I'm really pleased I made it, but it is for some one else.
Tishatang has some really good info, I did a lot of listening to him when he was in China, he has a lot of excellent ideas and is keen to help people.
jim
electricme
@ALL,
;D  ;D  ;D   Good news I've done it at last. ;D  ;D  ;D
At long last, my Stubblefield Coil is putting out some juice, first of all, it showed only tiny mvolts, then it was able to move the pointer on my big analog meter that I use for measuring Earth voltages, now I can light a Joule Thief.
Take a look at the below JPG. The NS coil isn't putting out as much as Lasersabers because it needs more wire on it, but it won't take me long to do this now.
Remember, this is NOT the output from a secondary coil as I haven't made one yet.
All I have done is make in a similar manner to Lasersabers coil.
I'm taking the output from the Copper wire (+) and the Negative (-) of the bifiler wires and driving the JT with this, the second JT isn't lit, (but I saw it light up for a couple of seconds).
To do a double blind test on this, I took a electrolytic capacitor, drained it of any residual voltage, charged it via the Stubblefield Coil, then connected the Joule Thief to the capacitor.
The cap lit the Joule Thief for about 1 second, so yes, this is indeed working. Yipee.
The coil incerases its voltage and current every time I wind another layer onto the coil, but the last layers it seems to be not so much, but the mA are getting better, but it seems the current will overtake the output voltage soon.
To me, the coil needs more wire layers which will give more output.
It's a wonderful feeling to see this working after all the years we have all been working on this thing.
The output is straight DC at this point in time, it may change later on though as I wind on more Copper and Iron wire, this seems to be the way to go with it, I imagine at one point this coil will begin to oscillate by itself, if and when this happens, we get the power out of secondaries from the collapsing magnetic fields.
jim
Layer        Dry          Wet         single coil         Turns        Current
  7            0.27v       0.50v         95mm              46            0.?      because I 4 got it  :-[
  8            0.30v       0.71v        100mm             44             0.?      ditto
  9            0.68v       0.74v        105mm             43            8.16mA rose to 29mA drop to 24.6mA
3445 = The Joule Thief LED being lit up, the unlit LED on the 2nd Jule Thief (which is sharing the current) is working, the resistor seems to have gone "high" and will need to be replaced, I bridged the resistor with a wire link and it worked OK.
3448 = Here is my meter connected while the Joule Thief is being lit, there is 0.37 mVolts still coming out of the coil while the coil is driving a load. ;)
jim
electricme
Thank you Jesus,
I'm about to wind another layer on this Stubblefield Cell.
jim
