IotaYodi
More thoughts on this. Im seeing a relationship between the telluric currents and the "Natural Ac" of the magnetic current of the pmh. Im still of the mind that the spikes from the telluric currents are running into the abundance of varied radioactive materiel's and metals in the Earth. If a scope shot could be done on the Pmh ac coil I would think the wave form would be uniform. It was stated that the Pmh ac coils magnetic polarity did not reverse. But at any given point I would think both north and south magnetic poles of each individual magnet pass the point as it flows through. It just doesnt do a total reversal in the path as a whole.
Added another wiring scheme.
What I know I know!
Its what I don't know that's a problem!
john_bedini
Jeanna,
Thank you for your latest comment on this thread.
I will say one thing to all of you working to replicate LaserSaber's Motor and his effects. I have done all this when I put up my pages on Stubblefield. My tip to all of you is to do it exactly the way he is showing to do it, do not try to second guess him as he is right on in what he is doing. I have spent two weeks reading everything here. I just wanted to see what is going on in my field as I started back in the 70's with my experiments in hidden energy, not really hidden if you understand what your looking for.
I will say this again stop looking for current with meters as it does not matter with this energy. What LaserSaber's films are showing is a separation in magnetic streams as electricity is all magnetic streams. Just placing an Iron rod in the ground will cause it to become very magnetic and if you switch it you have a motor function monopole wise. The digital meters do not measure magnetic current correct, only if you close the loop as taught in electronics, but that is not how this energy works. The Stubblefield coil is nothing more then a magnetic stream separator and you can see this if you watch his video as he clearly shows the effect of that separation. Think about what water is, that is why when the coil dries out you get  more energy.
The answer to that question is water is repelled buy magnetic currents so the coil repels the water out of it as it does this you get an electrical increase. It really does not make any difference what you use in place of the iron wire. I have used in some of my coils cotton covered  Nichrome wire in place of the iron. I have used just regular steel bolts in some of them. The best being pure cast iron powered cores which I made using cuttings from engine boring machines, it's free if you ask for it from an engine rebuilder.
LaserSaber made the perfect Monopole Motor, but you could use a special Darlington transistor to switch it, if you make it. Stubblefield used horseshoe magnets in his motor and the contactor of the time would have been mercury. Now think about copper chloride if you think you need current. One other tip here build the identical machine as laserSaber did and you will discover the effects in magnetic current and how it flows once it is separated, all electricity is magnetic, north magnets and south magnets in balance if you unbalance them you have electricity.
Again Thanks Jeanna for your kind words very thoughtful of you.
John B
Omnibus
@john_bedini,
So, how are we to measure the energy input into the electric system and the energy obtained from the electric system if we stop looking for current with meters? Why should, say, a Hall effect current probe not be used form measuring current? And, what about copper chloride if we think we need current? How does that work?
john_bedini
Omnibus,
I find several ways to do this. When I could not detect what your referring to as electron current. it is not really the measurement of current with earth batteries as they just developed potential voltage and very little current. LaserSaber has shown that in the videos with the compass is one of the ways to detect this by that movement. you can build a hall device with an amplifier also.
The thing to remember is that the earth cell would like to drive a very high impedance load. the copper chloride would act as a depolarizer for the earth cell allowing much higher magnetic current between the windings if the right amount is used. I think you all have built these devices, but how many have built motors out of them?. I have shown how to charge batteries with just the simple monopole circuit, you would do the same thing with his circuit with the reed. The other thing is that you can also build a very sensitive galvanometer.
I have built Monopole motors this way not saying anything about the windings in the machine, the transformer action can and does charge batteries with the spikes. Batteries just want potential and that will move Ions in the battery, that's all I have ever been saying. If your going to use textbook circuits then yes you need current but that is just a waste of energy. I do not know how long lasersabers motors have been running in this condition. I do know of clocks that have been running for years using this idea and are still running. You can also feel this energy by touch on grounding rods.
The thing about this coil is how it transmits audio through the ground and how far you can go and still pick up the signal, I did have a bout with the FCC over these frequencies I could use. When they got done nothing was left in the audio band I could use but I continued to experiment anyway even if the fine was steep. I just filtered out the bands they were on with steep notch filters. They can here you with these coils, ground radio transmission with no power.
Hope this answers some questions. But if you want a motor just follow LaserSabers directions then use the circuit that people use with the monopole circuits to charge batteries, they will work.
John B
Omnibus
@john-bedini,
I hope you won't get offended by that but I call that pseudo-science. And I don't mean that in a derogatory way but to distingush it from the generally accepted notions regarding the nature of current, energy and so on. I am a classically trained scientist and to me current is a directed flow of electrons. For that to occur you need to have the circuit closed.  Energy is the ability to do work and it is generally described by the availability of negative difference of the Gibbs free energy which one can utilize. In electrochemistry that's the difference between two spatially separated substances connected in a closed circuit through conductors of the first or second order. In this sense I don's see anything unusual about the so -called Stubblefield battery because it can be nothing but a galvanic cell. My understanding is that if somebody would claim OU he should provide clear evidence that the incoming energy, properly established, is less than the ougoung energy, also properly established. Now, if new kinds of energy are to be claimed then there should be ways to detect them by converting them into known types of energies so that the conventional energy balance can be found. If there is some kind of non-conventional energy balance to be claimed, it has to be explained very clearly why should that be used and not the conventional energy balance. I'll be glad to be proven wrong but so far I haven't seen anything convincing in this respect, except for maybe what Steorn is demonstrating.
