0 Members and 58 Guests are viewing this topic.
fathershand
Tishatang, glad to see you're back!  In an earlier post, you said that you would explain why we should use wood and cotton for the end plates and wrapping.  Can you explain why now, please?  Also, you thought that fiberglass and resin would be OK.  What were you thinking that these would be used for and why?
Thanks and I hope your  "shaky hands" will allow you build an EB soon and help us get this thing really going!
tishatang
Hi fathershand,
When you read historical accounts of Stubblefield, witnesses said the surrounding hills would glow, or the ground itself would seem to emit light.   Also, when concerned friends broke into his cabin to find him dead.   The cabin was quite warm with two polished disks radiating the heat.
It dawned on me, that this kind of power could be orgone energy, which glows blue or gives off blue light.   I then looked at the patent images, and sure enough, a cross section of the EB is exactly like an orgone accumulator.
An orgone accumulator is composed of alternate layers of metal and organic substances.  Research Wilhelm Reich.   If this suspicion of mine is true, then we do not want to construct our experimental EB with material that blocks orgone energy.   Plastic blocks orgone, but fibreglass and resin is OK and is used to build orgonite devices.
I don't think right off the bat we will build an orgone generator.   But, I also don't think that Stubblefield discovered this power right away.   It is
a growth process.   One takes baby steps and little by little energy grows as we make improvements.   However, once an orgone generator is in operation, you start to tap unlimited power.
Chris
Bob Smith
Tish,
You may be right about the orgone. However, I've begun to suspect that the glowing ground around Stubblefield's home had a lot to do with magnetic fields. Mehron Keshe has written that light has its own internal structure, and that it is fundamentally the result of interacting magnetic fields (to put it very, very simply). Keshe maintains that the interaction of magnetic plasmatic fields of planets produces light.  Keshe's technology uses a generated mag-plasmatic field which interacts with the earth's same field to produce various effects (including light).  My thinking is that Stubblefield's coils may have been doing a smilar thing, thereby producing light. Keshe's YT videos will give the proper explanation of what I'm saying in overly simplified terms. See:
http://www.youtube.com/user/keshefoundation
See his Keshe5 video to see what I'm referring to. More info is on the other videos as well as his website:
http://www.keshefoundation.com/home.html
A good recent talk radio interview with him explaining the technology is here:
http://www.redicecreations.com/radio/2011/06/RIR-110609.php
In my thinking, there is something to be said for interacting magnetic fields and the production of light, and I think the light-producing effects of buried SBs on Stubblefields property can be considered from this perspective.
As for orgone, perhaps there is a relation, given its bluish light associated phenomena. Here's a YT video to power immediately being harnessed from a Joe Cell:
http://www.youtube.com/watch?v=I4N32VuWxwc
Perhaps Stubblefield's coils became conditioned after awhile in the ground, and their strengthening magnetic fields interacting with the earth's mag field produced the glow. At the same time, perhaps they were also accumulating orgone, and perhaps at some point, there may be an overlap where both the SB and JC are actually tapping into one single energy source from slightly differing entry points.
Bob
tishatang
Bob,
Thanks for turning me on to Keshe's work.   It is amazing that one man discovered what the black ops have known and kept secret since the 1950's.   The power elites will do all they can to keep this technology from going public.   It is too big a game changer.   But, change is in the wind from many different directions.   Perhaps the current power structure in the hands of a few will be over soon?  And, we the people can enjoy modern technology.
To me, Keshe's magnetic plasmas and orgone energy is the same stuff.   Just different names and concentrations of orgone.   What differs is the methods used to concentrate and manage its energy.   The direct tie-in is when Reich pointed his cloudbuster at some stars and they winked out or moved away.   Reich thought we had alien visitors and went to the FBI.   He made a mistake thinking we had an honest government.   This was the real reason he was stopped and his books burned.   The fact he threatened the medical mafia with his healing by the use of the Orgone Accumulator added fuel to the fire.  Orgone is what was powering the spaceships and his cloud buster was sucking the orgone energy out of them.   There was no way the power elites and black ops wanted the secrets of orgone energy cat let out of the bag.  And, the same holds true today.  It is interesting to note that Keshe is using his mag plasma to heal just like Reich with his Orgone energy.   Here is a little bit of history from one of his burned books.
http://journal.borderlands.com/2010/round-robin-does-the-planet-earth-harbor-spacemen/
Hopefully, history does not repeat and Keshe does not end up dead in a jail cell like what happened to Reich.
Regarding the video of the Joe Cell charging a battery.   This could be surface charge?   A better example would be to show the battery trying to light a bulb.   First the dead battery failing and then the recharged battery lighting the bulb.   So, the video does not prove anything, but could have been better with a bulb as a load.
Chris
fathershand
I would like to insert my two cents, because that is probably what it is worth.  Unless someone can clearly show a link between the Stubblefield battery and the "blue light", then it is speculation to put forth the idea of orgone energy, etc.  I think it is better to stick to the scientific method in order to solve the "mystery" of the Stubblefield battery.  Further, lasersabre's youtube channel shows some pretty great work on this EB.  I am still looking to see someone produce an EB or a series pf EBs that produces some significant power, i.e., Voltage X Amperage.
