Cap-Z-ro
What you are saying makes a lot of sense to me joe...and may be the most reliable source of energy...unless of course the pole shift really does happen.
Regards...
Localjoe
Thanks cap,
          Sometimes as we grow so do our minds and we look at things not for the visible explanations (whats right there in front of your face) but really for there purpose or how they work :)
         Now ive gotta go find all the stubblefield parts and try this again
As far  a the interrupter i say we just try a regular old magnetic relay not actuated off the core, actuated on its own like a el cheap radioshack jobber!  I think looking at this thing as a tunable wine glass is the best anagaly i can make to get this project moving further than it has.  the core with very little magnetism is key as well that way the fields can collapse easily and give good discharge on the secondary once the ringing in tune.
Ok now dont laugh im going to ask some questions on my mind.-
                 How do we accurately sing out to mother earth.??? Ive got plenty of freq charts for shumman resonanse and charts for harmonics and octives. but theres something here that sits in my head that must have some bearing on this.
I talked about resonance and wine glasses ect.. every example of a "creative/constructive" is based off of phi 1.618.  there must be some logic behind it.. shauaberger realized that was the key to the vortex build..
We need to all be musicians here for a little bit and
1- find a way to play a note to the earth that will resonate with her magnetic field
2- find a way to measure or evaluate what gets sung back!
3- after testing find a self resonating interval that will yeild the symbiosis were looking for
a neon on the secondary should be enough to show us its working maybe even a little mod of an adverenko plug(single wire transmission)
No one really knows what kind of energy will come of the secondary. is it hf too high were meters wont register it but it might have great electrostatic potentials????????  i think a neon shoould do it for initial tests then maybe a little bank of neons
also ive thought about building electrostatic caps out of glass boylans soda bottles salt water and a metal container with salt water in it.  I think that maybe with the potentials were dealing with some old school playing may be necessary to see things modern science has since turned a blind eye to
Whats the diff between how tesla measured cps and how herts measured hz ??
With a smart group like we have here evaluating these questions i bet all the answers are right here just a little discussion needed
All this testing must be done with the thing burried... so wires should be wound to uniform lengths that will give us a wide span of freq response in conjunction with a cheap relay and variable radio cap or whatever is used.. I think i was so intent on making that interrupter work the way stubblefield did and not realizing it was only part of a lrc circuit used to excite magnetic current in an iron core... duh
that i missed what i was really looking for with the device.
even crazier analogy.. when one uses a plunger in the toilet.. did u ever notice that if you do the plunges air tight and at the right pace meaning in meter or proper interval tap your foot like a musician.. (nuts right) that the suction works 9 times better to undo the clog... or in our case release the flow..... let that one rattle around the noggin a bit with the ns coil in mind
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
IotaYodi
What I know I know!
Its what I don't know that's a problem!
Localjoe
So now my question arises how does the sun affect or determine angular frequency w(omega) of the earth and the other planets. Its the relationship i must understand how the suns gravity affects angular freq .. I know already that planets closer to the sun get stronger gravitational waves imposed on them and that
http://en.wikipedia.org/wiki/Gravitational_wave
"Two objects orbiting each other in a quasi-Keplerian planar orbit (basically, as a planet would orbit the Sun) will radiate" -wikipedia
Gravity doesent explain it .. it seems  that somethiing else here gives energy to our earth to power its electromagnet and keep is spinning. some unknown force from the sun maaybe
Theres a reason tesla preferred cps and i has to do directly with this.
Does the super charged plasma from the solar wind hitting the earth play a more ready part in our planets energy cycle  and angular freq than we know?
maybe i should look at this mystery backwards- what kind of power source is needed to keep the earths electromagnet powered creating a magnetic field here and sustaining life.  Think of the earth as a em motor i guess most broken down part
so if i were to have a working motor and no power source how would i determine a proper input source for the motor....  this relationship between the sun and earth will unlock the rest if understood.. feel like were close too. weve got way more gagets than the old boys did just not the proper education becuase they dont exist post 1920!!!  Fracking oil companies can let any one have anything nice!
I guess all this prolly isnt needed but theres a whole leg of physics thats been left by the wayside and i believe that its up to inventors like us to push forward if for nothing else out of respect for the wall sockets with ac power in our house right now and the pioneering men that tried to lead our world down a better path!
Localjoe
Interesting note
http://peswiki.com/index.php/PowerPedia:John_Keely       -credit
Some believe that the research of Nathan Stubblefield and his Earth battery system utilizing copper rods and iron rods. One could sink them in, probably, even at best, utilize Stephan Reiss's method for water-production by drilling very deep into the rock to hit fresh water - so Keely connected with Stubblefield, and Reiss hinted at equals battery-power from the earth's magnetic field using the earth-battery or magnetic induction amplifier of stubblefield, then this can be used for voice transmission over long distances, and also then a specific shape vibrated and driven into the ground, for water-receival.
now that im searching for the right thing its odd how many places its casually mentioned
@Iotayodi
i think your dead on with the tree antennas i looks like theres reports of huge cables going from the trees on the property back to the house it was said that an arc lamp was connected inbetween the tree antenna on the tree and the house...
arc lamp is a hell of a resistive load .. but it would be a constant on all the trees if built the same and would be the "constant" i was looking for concerning the pith ball array.. scary right lets use trees as antennas and well appearently humans must distort there natural magnetic feild enough to cause a change in power to the arc lamp resulting in the movement of a pith ball in teh apporopiate spot on the board in the house
... this might be easily buildable, or at least tryable
http://freeenergyportal.blogspot.com/2011/06/nathan-stubblefield-earth-battery.html - this place doesent mention the pith ball array but talks about the cables from the trees and the arc lamps.. seems to be the other part if it. what do you think?
great quote from that page
Now," Tesla writes later on about the transmitter that he was developing, "I attacked vigorously the development of my magnifying transmitter, now however, not so much with the original intention of producing one of great power, as with the object of learning how to construct the best one. This is essentially, a circuit of high self-induction and small resistance ( key words coming up) which in its arrangement, mode of excitation and section and action, may be said to be the diametrical opposite of a transmitting circuit typical of telegraphy by Hertzian or electromagnetic radiations."
What Stubblefield had discovered and what he did with his system.
Stubblefield was experimenting with ground radio since 1882, but did not patent his developments until much later. Credible witnesses saw his ground radio experiments in action during this time frame, establishing the historical priority of Stubblefield. While Marconi could barely send telegraphic "dots and dash" signals with great difficulty through a static-filled medium, Nathan Stubblefield had already transmitted the human voice with loud, velvet clarity. Others would adopt and implement the Collins system (Fessenden, DeForest, Bethenod, Braun), but none could duplicate the Stubblefield System.
Nikola Tesla performed double ground experiments with impulses as early as 1892, reporting these in lectures and patenting some embodiments in 1901. Not one of these later systems ever achieved the same results of clarity, tone, and volume of Stubblefield ground telephony. Tesla apparently never discovered the true powerpoints which powered Stubblefield's device. Priority in all these arts belongs to Nathan Stubblefield alone. In addition, his was the only system in which natural energies were obtained, magnified, and entirely employed as the empowering source. All other inventors used "artificial" sources (batteries, alternators, dynamos).
