Cap-Z-ro
Pirate88179
Localjoe:
Man, it is really great to see you back here again.  We have sure come a long way since you stuck those screws into the ground.  I don't have much time these days but I am glad to see the work continuing here.  I agree with your latest posts and one day, all of this will come together.
In a related technology, have you seen what has been happening in the Kapanadze topic area?  Already one replication and I know that technology is related to Stubblefield.
IotaYodi
What I know I know!
Its what I don't know that's a problem!
MW383
Interesting picture I never came accross before. My apologies if this was laready posted and I missed it. At any rate it has the name Love on its right edge, the person assigned 1/2 of the 1898 patent. These appear as standard inductive coils of the era and not exactly the coils outlined in the patent. But there are general constructional and proporational similarities between the coils in the picture and the cross sectional diagrams in the patent. I really like the big fat primary wires, no screwing around and such tidy windings too. I used to harp about winding cleanliness on this and other forums in the past. At any rate I thought the picture highly interesting.
Bruce_TPU
Hello Bill, Joe and all,
Having worked on this project a long time ago, you should know that through my work on the TPU, I think I have a way to make more power from this, using laser sabers setup!
Do any of you guys have one built, to test with?
Cheers,
Bruce
