0 Members and 45 Guests are viewing this topic.
hansvonlieven
sid10
maybe i should read to the bottom of the page before i try to correct someone who's been at this probably much much longer than me. I'm still trying to figure out how to read this meter.
I did get a chance to read Stubblefield's patent today and it sent my mind reeling.
Please forgive me if I am just repeating what others have already said, if you could get a steady 1.5 volts at 1 amp out of his electrical battery and feed it to the pulse timer, that was just posted, then feed the output from the timer to a bank of capacitors and use the capacitors to run some super efficient led type home lighting system, or charge a bank of deep cycle batteries that would feed a inverter....
does any of this make sense? or am I wayyy off base?
Sid
The only dumb question is the one that goes unasked.
sid10
whadya no any button worked, That you need to use a fiel format as small as possible to prevent time outs didn't occure to until my 11 yeas old told me so.
Kids what will they come up with next
Sid
sid10
someone asked if a led can be photovoltaic the answer is yes if its green. I came across a site that sells sun tracking devices for large PV arrays and it was using a set of three green LEDs as a means of turning the tracking motor on and off.
Humm spell check button wonder what that one does?
duff
@Hans
Ok - you are correct. I arrived at an incorrect conclusion...
Perhaps I should have said that I was never able to accomplish was a series circuit using rods in a common medium.
-Duff
