Bruce_TPU
@ Bill
You need not worry about this being galvanic reaction causing the voltage.  This is well known in science as someone mentioned earlier, called Telluric Currents.  This is used to locate minerals, leaks in pipes, etc.  Also, in Texas, it has in the past caused problems with some of our dairy cows.  Them poor moo moo's walking around with voltage at their hoofs.   ;D  Besides, we could increase the power and sell the earth batteries as hillbilly fishing aids.  Just add leads to the pond!  LOL
In all seriousness, with the bit of reading time I have squeezed in, late at night, it would seem that there are also free electrons in the ground.  This I think is good news.  I have considered your test with the little battery, and it caused the received voltage to increase after the battery was removed.  I will tell you what I am thinking, and I can hear a few groans now,  ;) I am thinking Electron tube.  This is what I mean by that:
To put it very simply, electrons are released by the heater.  They are repelled by a negative plate.  But then potential is added to the positive side, and all of those electrons come running over to the positive plate.  The greater the potential, the greater the flow of electrons.
If in the ground, (and I have no way to test any of this until I arrive back home in January) we set our Southern electrode for the negative and travel a distance (I own a farm and have a lot of room) and place our positive electrode in the North.  We then complete the circuit with resistor, load, whatever and like a tube, place a high voltage potential on the positive plate, perhaps from stored current in a cap, through a circuit, and it releases this pulse of high voltage on the positive plate.  This higher potential will attract free electrons in the ground and increase the overall power.  Perhaps this is the part of Stubblefield's patent, not there.  Add a high potential to them coils and perhaps all kinds of power starts increasing in flow.  It also sounds like some of the reports I have read on the incremental increase of power in his system.
But before we think that big, we need to test this theory.  Apply a higher voltage, low current to the positive electrode for a short time and see if the overall power increases as I think it should.  If it does, then for how long.  Then we configure a circuit to pulse HV from a cap that has stored our captured ground current.  And use it to multiply power.  This is my thoughts and a path that needs to be tested.
Holiday Cheers,
Bruce
cub3
My Apologies to all this is what should have come through.
G'day Ladies & gentlemen,
                                          I, came across this thread, prior to Christmas and it has taken some time to read it in it's entirety. The numerous links and downloads did not help, especially when one only has to use dial up  :-[
This thread appears to the most stable with input and respect from members, compared to some of the other threads and discussion topics that I have read.
Today, unfortunately I sensed some doubt. This should not be so. Collectively, you all have to put a lot of thought into this project.
Owing to my dial up connection, I have been unable to read and hence understand any of the patents, let alone enjoy many of the video's. Rather, at present my limited knowledge relies upon the post's on this thread.
OK What was the potential of the EARTH/AETHER in the past?
Why, should it be any different today, than in the past?  IT has been given (the earth) more over the years. What Do we know now? Whom have we followed! WHY? How do we learn again. What are we doing different!! ??
What, do we no longer know, recognise or see. Surely, we must come back to when their was an empathy with this planet.
There was a time where wo/man kind lived a different life, where we were not so pressured by every day hassles, had time to see and observe the world around us To feel, what we were and why existed.
It is our collective loss, it is not only Science, Government but something more!! Perhaps, a connection with this Planet we call home, how we view it, sense it, feel it, absorb it, are to be one with it, call it home, A sense of belonging and simpatico, we must learn to be part of this planet part of it and not merely walk upon it.
Apologies I digress, and indeed will again our mindset compared to those that we are endeavouring to at present to replicate or see from their point of view ad indeed science of the time. Sit back gentle folk, gather up your thoughts and battle on for their are many perturbations to yet be met and overcome. There was an old saying loose yourself before you find youreself.
In parting, for those that are interested in magnesium, if you have access to an Automotive wrecking yard, in the late 60's to late 70's a lot off high quality after market wheel rims were magnesium, if vehicle wrecked with a damaged rim yours for nix, a lot of Mag. for very little.
Unfortunately life very hard at present, I wish you all the very best and will keep an eye on you. :-*
Keep on Keeping on.
Den.
nightlife
I came up with this design thinking it may work on towers or above ground, maybe it will for what you all are doing here. Just turn them upside down and bury half of them.
hansvonlieven
G'day nightlife,
could you please tell us: What is the rationale behind your "frequency attraction device"?
Why is it supposed to do what?
Hans von Lieven
nightlife
hansvonlieven, attract and collect frequencies and or sound waves. The picture is kind of a cut out version of the design I have stuck in my head. The design would be a circle meaning all the components would be wrapped around each other. It should create a turbine affect.
