0 Members and 28 Guests are viewing this topic.
Pirate88179
@ All:
I finally found my receipt for the carbon rod
Airgas-Mid America
3000 Industrial Drive
Bowling Green, KY 42101
270-842-9486
Carbon Rod 1" X 17"  Item #ARC 4716-4000         Price=$21.77
They may have other locations across the U.S. but you could call and ask.  Hope this helps. They also have other sizes.
Localjoe
@Jenna
  Something weird I experienced was the Dead short showing on the meter... So i guess as far as a flow diagram by having the cap and a diode after the diode/led may be forming a recursive loop not found in most circuits... *** Brings up the idea to put one led on either side of the cap.. mr amos may have mentioned this or hans i cant remember ... but I think that should light both led's and charge the cap if done right..?
  Like in one of my first  posts i was able to run a battery in series with the ground and light an led from one copper rod to the positive of the led and the battery's negative to the led neg or grnd,  but in between the copper rod was the earth and then a zinc screw attached to the plus of the battery.   It worked very inefficiently but did so it was an interesting exp.  May this exp will give you more ideas conceptually to try with this.
@All-  thanks again for all your hard work this project and all the research has been not only mind expanding yet humbling at the same time.
        Salute to those who came before and those who will continue on..
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Pirate88179
http://www.globar.com/ec/maxcap-double-layer-capacitors.html
Above is a link to some really SUPER caps!  5.5 volt and 5.6 farads!!  Yes, 5.6F  It says they can keep RAM operating for WEEKS.  I think we need these.  Have not checked the price yet but will.  You electronics guys please let me know what you think about these.  Thanks.
hansvonlieven
G'day everybody,
Just a quick one for now, seemingly off the topic (sorry Joe) but it does seem to be further substantiation of my theory about perpendicular fields and their ability to increase substantially the energy flow in a system.
http://www.youtube.com/profile?user=anandaadhar
This guy is using a small magnet that he uses to create perpendicular pulses in a magnet arrangement. This is not a fake. The principle is known (see Stephen Kundel's motor) but here is a dramatic demonstration of a possible increase in power. I think we are on the right track. A lot further to go yet though.
Hans von Lieven
Artic_Knight
a couple of notes and i will post more later, as i am still catching up, when i referred to "charging the battery" i intended to hook the positive to your negative pole and the negative to positive earth at the same time, this however promotes electric current between the poles i think, but hey since we are experimenting wanna find out?
i googled farad and the definition is " farad is the amount of a columb of energy obtained by a cap from 1 volt current."
i have a 600 farad cap that is 200 wats from a tv... can you say fun? :D
so in short a farad is how effecient a cap is? im assuming?
