0 Members and 184 Guests are viewing this topic.
jeanna
Quote from: Localjoe on December 28, 2007, 02:03:41 PM
@Jenna
  Something weird I experienced was the Dead short showing on the meter...
Do you mean when the probe touched any part of the earth or even some dirt near the earth?
Thanks
I will look back at some earlier posts to review.
jeanna
jeanna
3
4
12
I guess no tables  :'( oh well
jeanna
Pirate88179
Bruce_TPU
Quote from: btentzer on December 27, 2007, 12:43:37 AM
(snip)
To put it very simply, electrons are released by the heater.  They are repelled by a negative plate.  But then potential is added to the positive side, and all of those electrons come running over to the positive plate.  The greater the potential, the greater the flow of electrons.
If in the ground, (and I have no way to test any of this until I arrive back home in January) we set our Southern electrode for the negative and travel a distance (I own a farm and have a lot of room) and place our positive electrode in the North.  We then complete the circuit with resistor, load, whatever and like a tube, place a high voltage potential on the positive plate, perhaps from stored current in a cap, through a circuit, and it releases this pulse of high voltage on the positive plate.  This higher potential will attract free electrons in the ground and increase the overall power.  Perhaps this is the part of Stubblefield's patent, not there.  Add a high potential to them coils and perhaps all kinds of power starts increasing in flow.  It also sounds like some of the reports I have read on the incremental increase of power in his system.
But before we think that big, we need to test this theory.  Apply a higher voltage, low current to the positive electrode for a short time and see if the overall power increases as I think it should.  If it does, then for how long.  Then we configure a circuit to pulse HV from a cap that has stored our captured ground current.  And use it to multiply power.  This is my thoughts and a path that needs to be tested.
Holiday Cheers,
Bruce
@ Bill and All
Bill, your little nine volt battery you tied into your negative electrode will not leave my brain..  ;D
I quoted myself, talking about putting a higher potential on the positive plate, creating a dipole and encouraging more free electrons to be attracted to our voltage output.
Well, I also found this, from a link that Pese gave out some time ago.  Again, I will highlight the key parts that shouted at me.  I will be ordering my carbon tomorrow.  Thank you for finding that link.  It should be on my stoop, when I return home.
I have a plan formulating in my mind.  I predict that I will have that micro tpu, ground powered by January 14th.   ;)
Quote:
"The induction coil which bears his name is equipped with three coils which are wrapped around and upon a heavy iron core. Bare iron wire and cotton-covered copper wire are wrapped side by side, comprising a primary coil body. Each layer of the primary coil  body is covered by a band of cotton insulation, bringing four wire leads to the coil terminus. Two leads of iron and two of copper are external to the coil. Commercial electrical power is obtained through these connective terminals.
In addition to this bimetallic winding, there is a third winding: the "secondary". This third coil is insulated from the primary bimetallic coil, serving as a trigger device. Presumably, a stimulating impulse shock was introduced into the tertiary coil, after which the upwelling electrical ground response brought forth powerful currents in both iron and copper coils."
http://www.icehouse.net/john34/stublefield1.html
"...after which the upwelling electrical ground response brought forth powerful currents in both iron and copper coils."
I think this will be the secret to gain more power!!  IMPULSE SHOCK  :o
Holiday Cheers,
Bruce
Pirate88179
@ Bruce:
Yes, exactly!  Just to be clear, I didn't come up with that idea, I read it either from where you posted from, or elsewhere.  Actually, I remember reading this in several places, possibly on the patents? I believe they called it "priming the pump".  What I don't get, with my somewhat limited knowlege, is why the earth responded a bit like a capacitor when I did this?  I mean, we pump all sorts of power/volts to ground every day, right?  Mostly ac ok, but some dc as well right?  So, where does this go?  I searched all over town today for another magnesium block and every store was sold out.  I can't believe this.  These things are usually all over the place.  K-Mart had the exact one I am using on cell 1 for $1.99 but, they were sold out! I really want to do some more research on the "priming the pump" method.  Once I have my other mag. block, I will have 2 cells identical in every way.  I can use one for a control and pump volts and or amps into the other and see how high it goes and how long it stays there, etc.  Without the coil arrangement Stubblefield had, or the TPU device, I don't think it will stay forever in my garden.  But, isn't the fact that it stays there at all a little amazing? And, this from a 9 volt. (old one too)  I mentioned my car battery charger in several posts.  With your experience, do you think this is something to try also?  I don't remember what it is rated but, runs off ac of course, and will charge dead car battery (enough to crank over) in like 20 minutes.  Should be some amps there I would think.  Can you see how Joe's original post got me hooked into this?  I more I think I learn about it, the more I find that is not known about it.  BTW  when you order the rod, it had to be shipped here (to Bowling Green) from their supplier.  You might be able to have their supplier drop-ship it directly to you and make payment arrangements with the Bowling Green, Ky people.  Would save double shipping.  They were very nice to me and easy to deal with.  I told the guy I only wanted one piece, not 10,000 and he said "hey, an order is an order." I liked that. Now, if we could find magnisum plates or rods of decent size...who knows?
