0 Members and 184 Guests are viewing this topic.
Artic_Knight
i apologize for the miss information i was getting 1-2 miliamp
i know a led uses 20 at 1.7 volt thats what my clear red led is rated at most likely the same as bills since it was the cheapest on electricity i could find from electronic store.
i can get a steady .52 volt at 1-2 miliamp, and its rate of fluctuation is a pattery, it would switch twice a second i think.
Pirate88179
@ Artic Knight:
That's a nice looking cell.  I have an idea...maybe.  I like the way you used plates to multiply the surface area.  What if, you made a cell with one type of metal, and another with another type of metal, ie carbon plates on one and put it in the north position, and magnesium plates on the other?  Or, substitute any opposing metals (as far away from each other on the galvanic chart) that you can obtain?  What I am getting at is that you have devised a way to get a whole lot of surface area in a small package.  I believe that if you used them like we are doing already, you might easily surpass any reading we have to date. If  I was not so low on funds at the moment, I would love to try that out.  This way, you would have the north/south thing in your favor as well as the distance between the two disimmilar metals which will boost the output.  What do you think?
No problem on the readings, it is very easy to mix up while doing this stuff.  That is why when I see someone post that they are getting 2 amps, I question it, not that they are lying, but, possibly misread the scale.  Let me know what you think.
Pirate88179
@ Hans:
Thanks for posting the link.  I read the pdf and saved it for later ref.  So, you think that this type of circuit would increase our power? There is a lot about that circuit that I don't understand but, our old friend resonance is involved. Maybe someone else that knows more about this than I can comment.  So many ideas here, and so little time.
Localjoe
Quote from: Pirate88179 on January 02, 2008, 08:26:21 PM
@ Artic Knight:
Bill i think it was Freezer who posted the cell your talking about :)
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Artic_Knight
well im interested in running some more tests, one is with the tesla coil as a antenna, another is to get another aluminium rod and cut the steel in half, now mind you i have done all i can at this point based on what we have here to optimize my output with 2 poles,  i probed for best voltage they are only 6 inches roughly in the ground and i sanded the aluminium. the steel is galvanized. these rods are roughly 1 to 1.5 inch thick.  i need a proper capacitor and i will make a transformer to step down the voltage and that should light a led for me nicely. but i have not gotten there yet. i can say that to tie a led strait to this cell does nothing for me! no light! i believe its mostly due to the voltage at 1/3 required for the led.
i have read an article about the faraday disks that hanz posted and in it they made mention of waves of electricity carrying more potential than just the electricity. this i believe is relevant to this thread and i will elabrate.
you have one pulse wave of dc (what we are getting) it is rated at 1 volt at one amp. well the volt is how high the wave is and the amp is how long the wave is, riding on this wave is another bit of energy for some reason not seen by our volt meters but harnessed by our capacitors perhaps it is the collapse of the magnetic field of the wave? or maybe just the collapse of the wave just of itself?  this wave has that extra energy that turns it from a 1v 1a reading to a 1v 3a potential.
this is something that would be unproven as it is not easily measured and would require a radical invention to prove, hmm i see no shortage of them here all one would have to do is look at the TPU? coil device made mention of earlyer in this thread. it would create a magnetic field and harness the potential from it then the field would collapse violently creating another magnetic wave generating more potential!  i believe these waves are of high amplitude and low voltage which would go along with what i have seen on my amp meter, if one of the magnetic "lines" of the planet crossed my battery every second then i would get an amp, after it left and the field collapsed i would get 2 amps and over again!
just for reference i am using aluminium and galvanized steel if anyone has those metals and wishes to try, it was spaced 3 feed apart roughtly and the aluminium was an inch deeper roughly. i by force of my hand stuck the aluminum against the ground firmly till i found the place of highest voltage then hammered into the ground.
