Pirate88179
Hans:
Great pictures.  If this works today, this should be an enlargement of the coils.  I tried to clean it up a little but my software is limited.  It looks like fine wire wrapped around some brass assemblies of some kind. I want to read the patent on these things.  Thanks.
hansvonlieven
G'day Bill and all,
I am not so sure about the brass. To me, on first impression it looked like an old fashioned porcelain insulator used by the telegraph companies at that time. Hard to tell. Perhaps they still have one or two of these things in the museum where they exhibit some of his devices.
Hans von Lieven
Bruce_TPU
It would appear from your photo, Bill, that Stubblefield's coil(s) were on top of a rod.  So he inserted the rod into the ground and the top coils never went into the ground.  They look nothing like his patent.
Bruce
hansvonlieven
This is NOT his earth battery btentzer,
This is a different device.
Hans von Lieven
hansvonlieven
Just to give you guys something more to chew over.
Hans von Lieven
