0 Members and 45 Guests are viewing this topic.
Pirate88179
@ All:
OK.  A new mA record here with the new cell!  I will be making a few posts to show some pictures of today's experiments.
Results: 8.98 mA
This is my best thus far.  This picture is of the meter on the mA setting and it was actually a bit higher (9.3) but quickly fell to 8.98.  As you will see in the following pictures in the next few posts, I wired everything together for a major test the first time out.  I was going for broke.  I tested the new cell in many different configurations while hooked to the meter reading vdc.  I finally found that I got the best vdc reading with the cell vertical, so I burried it that way.  I dumped a little water on the newly burried cell as I always do to help the soil conform to the area of the cell.  If it holds as it has in the past, my readings will go up as it dries out some.  Plus, the soil is still wet here from a lot of rain several days ago and as that dries, things should get better.
Not as good as I was hoping for but, my best to date.
Bill                          PS Freezer: nice work on your fabrication.
Pirate88179
Here is a shot of the meter with :
1.45 vdc
I obtained this along with the 8.98 mA.
(sorry for the multiple posts but if I attempt more than 1 photo per post, it times out on me)
Pirate88179
This is a shot of the top of the new cell as it is in the ground at this point.  I have a general overall shot of the entire setup which I will use paint and label so it is more clear to all. (I am still excited here!)
OK I'll try to post this again. It said "cannont find overunity.com"
Bruce_TPU
@ Bill
Bravo!!  That is awesome news!  But you never gave the voltage.  What was your voltage?  ;)
EDIT:
Found it!!  We posted at the same time.
So, 1.45 volts @ 8.98 ma gives us .013021 watts.
But to build another one would cost you what, $30 USD?
Cheers,
Bruce
Pirate88179
This is a drawing/photo of the test layout used today.  If it is not clear, or anyone has any questions, please ask.  Thanks.  I am going back out to see how many leds I can light, etc.  I know it's still not a lot of power, but, still heading in the right direction.
@ Bruce:
I am glad you are getting mA now.  Blown fuse? Hey, it happens.
