0 Members and 138 Guests are viewing this topic.
Pirate88179
Jeanna:
Maybe try something a little closer to the diameter of your carbon rods for the "probe" to make your holes.  Also, cement is very porous, as you know, so I would also try the water treatment once planted to help them get better connected to the surroundings.  I have always done this.  Once it dries out a little, the results go up and appear to continue to do so.
P.S.  I sent you a video.
Bruce_TPU
Morning Bill,
I am in definite agreement on testing a Freezer type cell, made of magnesium and Carbon.  I am still awaiting my own magnesium blocks.  When they come in, I will put them into my East West neutral line, and cut 12" off of my carbon and place that on the Positive line, and see if I get a bump in voltage.  I also want to replace my 12" spikes with smaller, thinner diameter and see if the ma's are affected.
So we need to find some thin sheet carbon and magnesium.  Hmmmm.....  I wonder how tough that will be.
Cheers,
Bruce
Localjoe
@ All
Alright i dont even have dry ground and im goin out to build this thing today
http://blog.makezine.com/archive/2007/11/make_a_joule_thief_weeken_1.html  If you guys have the money for it , no more than 5 bucks this is a real easy joule thief and a tutorial video ... Thanks to all for your continued efforts and i only wish i could be out there with ya.
        Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Localjoe
Quote from: btentzer on January 10, 2008, 08:43:50 AM
Morning Bill,
Cheers,
Bruce
I could be way off here but do you think hardwood ashes ... or lots of paper ashes with a little moisture in a hole... I guess thats not technically carbon but maybe a cheap alternative.
also i found this hunting  http://www.acp-composites.com/acp-gp.htm
jeanna
@ Everyone,
Bill is telling me that the wetness is significant. Others elsewhere have also mentioned that dryness does not make it worse but seems to make it better. I am wondering if the constant rain and very wet soil now are conspiring to make the low voltage and non existent amperage I see.
Is anyone else noticing the effect of wetness on their batteries?
(This is for information, it won't matter in my mountain where it is very dry.)
thank you
jeanna
