0 Members and 45 Guests are viewing this topic.
jeanna
Quote from: nightlife on January 13, 2008, 03:49:00 PM
Here is something you all may want to try. I found that flat metal works better then the round metal for the post. Out of 15 cups I used, I got almost 4 more volts using frat metal insted of round metal.
4 volts!
wow
How did you set this up?
15 cups? do you mean you are doing a cement pot type of thing?
I have a couple of flat pieces of steel I could try. I have an Aluminum can I could fill with earth and try. 4 volts!
jeanna
nightlife
jeanna, that is was the difference I got from using water in cups. It may help with what you all are doing using the earth.
jeanna
Quote from: Localjoe on January 13, 2008, 03:51:34 PM
@ Jenna
i mean from the electrodes in the ground  to a super cap or other cap and off those leads to where the input from the battery would normally go on the circuit.  Hope that helps
        Joe
Yup. It does.
I may want to solder  a new cap arrangement.
thanks Joe,
jeanna
jeanna
OK a new little report.
Still no light though. :'(
I changed the fuse in my voltmeter. (thanks, Freezer)
Cu pipe to mg block
1.35vdc, 2.3 vac, 0.038A
C4 rods to mg block
1.27 vdc,  1.8 vac,  0.016A
C filter granules to mg block
1.4 vdc, -.8 vac 0.035A
I jabbed the + end of the jule thief mit light into the carbon granules and clipped the other side to the clip that goes to the mag block. NOPE.
It's 2PM here now, (10 PM in Germany) I still have another hour. and it is sunny :D any things I forgot?
jeanna
Localjoe
We need to have bill try this he's the only one with enough current to use this probably. Good work jenna, ps did you have the cap in line with your electrodes powering the thief?
                                                           Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
