Pirate88179
@ Hans:
Back to business is correct.  Very interesting theory by this guy.  I believe this is just another way of stating Newton, which I believe.  I mean, separate water into hydrogen and oxygen takes electricity but, combine the two and you get, electricity. (As powered our American space flights via fuel cells)  This is fascinating.
Shifting gears a bit.  I have been thinking about what my experiments have been trying to tell me. (I can be a little slow)  Thinking back over my formal education in this area, I remembered that electrons always carry a negative charge, and protons always carry a positive one.  Fine, as far as it goes.  Why then when we have a "current" in a wire it is always electrons moving and not the protons?  Why not both?  And, also why not both interchanging at some frequency which mimics our "ac" which might explain some of our readings, and why Stubblefield could use primary and secondary coils which we know should not work with dc.  Just some food for thought because I have seen in my experiments that one electrode that is ALWAYS positive can easily be made to become negative, but yet, you are still using the same materials.
@ Jeanna:
I commend you for your forward and out of the box thinking. Finding something new NEVER happened because someone else did it just the way "they" have always done it.  This is exactly why I enjoy being here so much.
jeanna
QuoteI have seen in my experiments that one electrode that is ALWAYS positive can easily be made to become negative, but yet, you are still using the same materials.
Bill,
Thank you for restating this. It is the reason we know we are seeing non "galvanic" reactions in the earth.
QuoteNot long after the Telekinetic Effect was discovered, I also managed to found technical ways of releasing it (through an acceleration or deceleration of magnetic field force lines).
Hans,
Thank you for bringing this to this thread. Jan Pajak, as you know, works with the pyramid form. There is a kind of heat produced inside the pyramid. I was at a whole life expo once where someone was selling pyramid corner joints. They had an 8 ft pyramid on display and there was a line of people wanting to experience sitting in the chair. After sitting for 10 min (it was an expo) everyone was asked what it had felt like. The survey showed that there were many similar reactions but the one everyone had experienced was the sensation of warmth. Now, there is no thermometer that registers this warmth (that I know of) but all the human bodies registered it. The other sensation that was almost universal was the feeling of tingling. Now, tingling would mean nerves and nerves operate chemically to produce electricity in our bodies.
I think these things are related by magnetic events.
The electrons (or charge) going down a wire create a magnetic field around the wire - An inductor coil uses the magnetic field produced by something (usually an adjacent coil that has electricity going through with its consequent magnetic field) to produce electricity.
If we can sidle up next to a magnetic field and make the right size and shape of inductor coil, we should be able to see electricity on some wires.
A related event:
Something happened to my joule thiefs. I made the first one then 2 or 3 days later I made the second one with a red led. Yesterday I couldn't get the red one to light. I even recharged some batteries and it didn't work. Then I went into the room where I had put the first one, and I found that it doesn't work anymore either. - I may be making the wrong conclusion, but I decided that I think it is that the magnet that I used is too big and too strong and it eventually blasted the transistor and or the LED.
So, I woke up this morning thinking about the +'s and the "holes" as they are described in transistors, and I have been wondering if the way a magnet can blast a transistor is that it just fills every bit of potential in the doping of the Si and so nothing has any reason to move.
In the galvanic part of what we have been finding on our earth batteries, I think the doping is from the local soils and their conditions. It is like the inside channels of the transistor with little pockets of more or less. In the transistor, once you have achieved .7v the electrons move out, but they are always replaced from the other side so the transistor continues to function as it was designed to. (unless too much voltage or too much magnetism blast it)
Our earth and its magnetic field is so big compared to us maybe we need to be isolating our systems like transistors, somehow so we are on the edge of the field so we can get the effect of it. I don't know how to do this, but I wanted to share my morning musings with everybody. Maybe someone else will know or have more ways to try to get at this.
Tesla was always talking about the dielectric. The dielectric could be seen as the separator. In a way, maybe Bruce's 30 inch spacing and my cement pots are enough of a way to separate.
aaugh!!
jeanna
ian middleton
G'Day all,
@Hans: Thanks for the reminder about Pajak. Interesting stuff.
  All those who believe in telekinesis...... raise my hand.  ;D ;D ;D
Ian
Pirate88179
@ ian:
Good one!! Ha ha. I'll have to remember that one.
@ All:
Some potentially (pun possibly intended) good news.  It is like 12 degrees here but I wanted to check on the new cell
that produced my highest results and then stopped.  Well, everything I check on for mA was 0. Every combination.  I got to thinking about when someone posted about the fuse on their meter being blown, and once repaired, he obtained mA, so I
went inside where it is warm and, low and behold, blown fuse!!!!  My dvm is only about 4 months old but I must have "overloaded" it in some manner to have blown this.  Now, I will have to try to find a replacement fuse (very small weird kind) but at least, I am still producing mA.
jeanna
Here is a picture I am uploading for my symbol. I don't know where else on the web to put it but here. ;)
jeanna
