The ~~~~"RACK"~~~~~
Started by innovation_station, October 21, 2007, 01:13:53 PM
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
innovation_station
hello all
3 freqs are mandotary!!!!
when force feeding  and always until we have a poperly built coil then the coil will make the 3rd on its own and then we will only need 2 freqs but!!!   if the freqs are as close as i think they are humm......
then maybe just 1 freq genny and a crystal or somthing like it to make the second freq from the first
and dont forget the coil makes the third  ;D
ist
just wireing it all up it will take a wile i have decieded to use ribbon wire from a computer to hook it all up  because my bottom will swing open to work on the gennys with ease so i will need neat flexable wire and ribbon wire fits
acerzw
innovation_station
what cable?? not sure i follow you corss talk is a bad thing interferince i get that but hummmm....
ok here is a pic b4 i go any further on the wireing  will interferience be a problem with the ribbion wire i have chosen ?
please let me know as i do not know  if it is a problem i may have a solution i have some cat 5 dirrect bariel sheilded cable but it is a real treat to work with it is gel filled for frost and such cold but if i can avoid working with it then that would be great so some one let me know if it is a must for cables to be sheilded in a set up like this
thanks
it seams somthing is still missing from the mix to have a working ring
now that is assumeing i have the right amp! the right freq gennys!  and the right ring  but still somthing is missing  not the mag eather
now anyone got a guess what is still missing ?!?!?!?!?!?!
i hope so cuz im almost at wits end thinking what is missing the only thing i can come up with is phase!!!!!   hummm....  maybe the phase invertor !?!?!?!?!?!
but not so sure just yet
comments??
ist
innovation_station
well i got the ribbon wire done and run but i still have to find 4 more pots 2 of each 1m 50k  i added the freq gennys on a hindgs door  for easy access a bit more soldering and then it is the freq genny's power supply and it should hooked up in split rail mode like a computer power supply so i will use 1 of those  and it will be in an external case to the board
so not that much left on this peice of the puzzel ;D
ist
