Rodin Theory & Coils
Started by acerzw, October 28, 2007, 05:26:57 PM
acerzw
@amigo
I suspect Localjoe is referring to the possibility of using the rodin coil as a transmitter and receiver for superluminal scalar wave communications. I suspect that it could be used in such a way and it would probably be more efficient than a device based on a normal coil.
Some go as far to say it can be used for teleportation and that it has been done! I will believe that when I see it, I currently have not been able to find a theoretical mechanism which supports the idea to a decent degree. While I do believe in multiple dimensions and know of a number of ideas that support that, none of then fit the bill.
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Localjoe
@acer
agreed , At least IS didnt try to tell you it was for time travel... i told him to msg me last year :o... Any the patents are from naudins page and he gives a short descripiton on how the transmitter shootes through foil and other metals that normal rf does not. so its worthy of some investigation.  Teleportation ... was a stretch as well but energy is energy as light is energy as electricity is energy which says we just need to find different ways to transmit energy of different phases of it along the spectrum.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
amigo
It would be interesting to test that idea of superluminal scalar communication using the Rodin coil but question is how close they need to be (not distance wise but look-a-like) or is that a factor at all?
Winding one of these coils would be an exercise in patience to begin with, and making two, boy... :)
Also, do we really need the Rodin coil for superluminal communication test via scalar band at all, we could probably just use something less complicated (as if) based on Tesla's works?
Danny
Hi, A big hello to everyone!
Interesting work!
I'm interested in the free-energy aspect of the Rodin coil as opposed to the communication side.
I've spent some time viewing, reading, and trying to comprehend Rodin's work. He mentions specifically that with the coil, temporal (time) and spacial(wire placement) considerations are paramount. Frequency, and size of toroid, affect the relationship between the two. The following summarises my notes and my build plans with reasons for choosing the parameters.
a. We know there are two wires wrapped around the coil; lets call these wire A and wire B.
b. He says wires are pulsed as a triplet. e.g. Pulse wire A for duration X, wire B is off. Immediately followed by Pulse wire B for duration X, wire A is off. Immediately followed by both A and B being off for duration X. In other words the repetition time is 3X.
c. When both are off this is the time that you get free flowing energy in the SPACE next to wires. He specifically states that in the space 'S' there is no restriction, no friction, to the flow of energy.
e.g. If S represent the space then on the toroid the wires go ABSABSABSABSABS.
d. My take is that if a third wire is wrapped in the space 'S' this is where energy in the form of overunity electricity will appear ?
So far so good. So rather than wrap bifilar, wrap trifilar fashion. But what degree spacing should be used when weaving around the coil ?
Rodin does not say in the videos what degree to use between each successive turn on the toroid but on one of his webpages, a botanist? has observed that Rodin's number patterns work with plant growth. He has measured the angle to be 137.5 degrees. So I'm going to use this degree measurement.
The 137.5 I believe is also based on phi. 360/137.5 is 2.6181818 recurring.
My approach is going to be to keep marking 137.5 degrees one after the other going around the toroid marking the toroid 1,2,3,4 etc.
There must be a way of getting a CAD program to do this on a paper template ?
It'll take 144 trifilar windings, 137.5 degrees apart, to get back exactly where I started on the toroid. This equates to 55 times around the toroid.
The math is 144 * 137.5 = 19800 degrees
19800 / 360 = 55.
I think precision placement of the windings is essential which means I'm going to start fairly large.
In order to fit on 144 turns, I'm going to start with a toroid with inside diameter (diameter of the hole) of 11.46 inches diameter which has circumference of 36 inches.
In other words an average of 4 turns per inch (144/36) once the toroid has been completed. I'm thinking 1inch for the diameter of the toroid tube, if that makes sense.
Connecting the wires.
We got 3 pairs of wires each pair being the start and end of one of the trifilar wires.
I thinking enamelled wire at the moment.
One pair is connected across a 110V household bulb. I think it's probably important to have a load rather than just measuring volts on an open circuit so that a current is manifested should a voltage be generated across the output pair. A flow of current is obviously required to generate a magnetic field which can further react with the repetitive pulse on wire pair A and wire pair B.
Rodin tells us in the video that the current must run in 1 direciton in say wire pair A and must run in the opposite direction in wire pair B. So this tells us how to connect the wires to a pulsing circuit. The pulsing circuit has to do A followed by B followed by both OFF and repeated.
The frequency is anyones guess. Some multiple of 144 ? Or perhaps a multiple of the schumann resonance ?
Other thoughts I had was that the wire pair A is driven open ended, as is wire pair B. In other words just applying a voltage onto the wire would be sufficient for an effect. But who knows ?
The only other thing left is to determine a working voltage. I'm thinking 12V to 24V as my electronics skills on pulsing can deal with this. My intuition says with a precisely laid out coil, along with precise,stable and fine frequency adjustment, low voltage will be fine. With rougher placed windings and unstable frequency I think a much higher voltage will be required.
My only problem is how to create a toroid, at the size I want, for the windings ?
Does anyone have any ideas on how to do this or a company that can provide toroid cores ?
acerzw
Well looks like Marko is about to make a new series of google videos, thought it is unclear how long they will take to appear, the original ones are 15 years old and he has developed his work a lot since then. It is all in an interview at the excellent Red Ice Creations Website, here: http://www.redicecreations.com/radio/2008/01jan/RICR-080120-mrodin.mp3
There is also a good interview with David Willcock of the Divine Cosmos, here: http://www.redicecreations.com/radio/2007/12dec/RICR-071206-dwilcock.mp3
I have been looking at Marko's work again and knocked up a pdf which basically combines his number patterns/geometry from his web page as a reference for myself. There is a bit of artistic license as it is my interpretation.
I am attempting to work out how this ties in with Standing Columnar Waves which I have posted on GK's Heterodyning thread about before, as they are common in nature and are generated by Pyramid's etc...
A
